How much cam
Old Oct 5, 2006 | 05:53 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default How much cam
How much cam do I need to run 11:1 compression?
I have 236/249 at .050 with a 112 LSA cam hydraulic roller.
Planning on a 383 with flat top pistons
Old Oct 5, 2006 | 05:58 PM
gerry72's Avatar
gerry72
You can go bigger if that's your true compression. But you can also go as small as you want if you can manage the detonation with the high cylinder pressure.
But really, the question is how much compression do you need to be able to use a particular cam? You should be fine with that cam at that compression.
Old Oct 5, 2006 | 09:33 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Yes you have it backwards, normally you pick a cam, heads etc. that compliment each other, and then you choose pistons for that the compression ratio you need to run the cam
As stated above, you will be fine at 11:1 CR with that cam
Old Oct 5, 2006 | 09:54 PM
Guru_4_hire
Cruise-In V Veteran
I have everything except a rotating assembly.
I refuse to do things the easy way.
Old Oct 5, 2006 | 10:54 PM
StickShiftCorvette's Avatar
StickShiftCorvette
I have 355 with 10.67:1 CR. I run Brodix -8 Pro Heads (2.055 intakes) and run a Comp Cams 294S Magnum cam, 248/248 @.050.
With a Victory Jr and 750 CFM Holley, this is a great combination. At peak measured with a G-tech, it has only 90 HP less than my new SRT-10 Viper.
To How much cam
