Por 15 first timer
1) After i sandblast the frame, do I have to use any chemicals to prep it before using your product? What about the areas that I used rust converter on...can I just sandblast those and paint over them afterwards...or do I have to prep the metal after sandblasting?
2) Can I do the frame in sections over a week or two ...or do you recommend painting it all at once. I was thinking that I could possibly sandblast one section of the frame, coat it once with por15 and do the same the following day with a new section, until the whole frame was totally coated once. I would probably coat the entire frame again the next day for a total of two coats. Would this affect its bonding characteristics?
3) Can I apply por15 to previously rusted surfaces that have been sandblasted to a clean metal surface? what surface preparation is required here?
4) After I sandblast the frame, do I have to keep my hands off of it until it is coated with por15? I'm referring to oils on your skin. Do you recommend painting the frame quickly after you sandblast it...or can I touch the frame without any worries of removing por15's bonding capabilities? This is a hobby to me and I have a limited amount of time I can work on it each day of the week...I'm very busy.
Thanks in advance for all of the help guys!
in you case since you are blastine the fram you can do one of two things
POR 15 is not meant to go on bare metal witout prep, you can either use thier metal ready product, or use a self etching primer
you can do the frame in sections with no problem , just remeber to prep the bare metal before applying the POR 15.
if you are brushing the stuff on , it goes one pretty thick,and a second coat may not be required. If spaying, be sure to thin it some then wait 30 min between coats, but either way, dont wait more than an hour or so between coats.
for question 4, same rules apply....metal ready then apply the POR as per the directions.
I am not sure about appying POR over rust converter, best to call them and ask...
also POR is UV sensitive, and while on the frame its not an issue since it wont see sun, a top coat over doent hurt.
The way I did it was to blast the frame, applied a self etching primer then applyied the POR, and the results were great...
other wise apply directly to the rusted areas, thought the fished product wont be as nice.
good luck and remeber this....
after use, make sure the seal the canister TIGHT... if you dont, the stuff will turn into a lumpy goo that is totally useless, and the stuff is pricey....
overall i say its a good product when used as directed( naysayers welcome to disagree
)also, Eastwood makes a simlar product that is not UV sensitive, you may also want to consider......
cheers
tim
Steve
gbryning@comcast.net
When it is dry it is tough as nails, you can hit it with a hammer and it won't chip.
As for which I think is better... I guess I'd say the Eastwood product only because it's less expensive. They're both tough as hell when applied properly.
Eastwood keeps burying me in catalogs and I think they have widened their product line for R.E.. I don't know about POR-15. My use of both these products dates back about 2 years.
Oh, and if you spray any of these products get a mask on. You do not want this stuff in your lungs... or on your skin unless you really like the color.
But most importantly PREP AND APPLY EXACTLY THE WAY THEY TELL YOU."
I glass bead all my jobs, use POR15 Metal Ready for 30 minutes, rinse, dry, and then POR15 black, when just about dry I'll shoot the top coat and then let dry and harden a few days.
If I paint over rust it will peel in time. If fact it fails pretty bad, coming off in strips. If prepped then it stays on. I've have steering box that was exposed to high heat and the top caot cracked but the POR15 base didn't.
I put por on my truck frame where it's out of the sun, and it still got chalky. If your metal is blasted clean, use an automotive paint. Por 15 has it's place, but so many people think it's magic.
