A/C Fan Blower Problem
Old Sep 15, 2001 | 06:01 PM
DEN78SA's Avatar
DEN78SA
Default A/C Fan Blower Problem
The A/C fan blower motor runs for a little while then stops, then starts operating again. This just started today, what do you guys think could be the source? I figure that its not a fuse, since it comes back on by itself. Thanks for any suggestions.
Old Sep 15, 2001 | 07:13 PM
The Wanderer's Avatar
The Wanderer
Default Re: A/C Fan Blower Problem (DEN78SA)
Loose ground maybe?
Old Sep 15, 2001 | 07:44 PM
curly's Avatar
curly
The only true way to know is check voltage at the blower motor. Ground, switch, or even motor are all possibilities. ;)
Old Sep 15, 2001 | 10:55 PM
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
If it does it on all 4 speeds, then it's probably the motor itself, if only on high then it's probably a relay switch that provides allows full power to the motor. I believe the switch is right inside the engine compart, passenger side firewall, easily accessed.
To A/C Fan Blower Problem
