??? speed odometer is bouncing around???
Old Sep 15, 2001 | 10:28 PM
Bills17n72's Avatar
Bills17n72
Default ??? speed odometer is bouncing around???
Ok friends
I have a 79 and I have noticed that the speed odometer is starting to bounce around, not to much, but it is starting to bother me. It will very about 4mphs,I have seen some other people mention about this before, but I guess I should have paid attention, can anyone help me out?????
thanks and have a good weekend Bill B
Old Sep 15, 2001 | 10:59 PM
Torcher's Avatar
Torcher
Default Re: ??? speed odometer is bouncing around??? (bbryant200)
Grease the speedometer cable and or replace it. It may be dry and is starting to bind inside the casing! :eek:
If you have cruise control, take it loose from there and pull the cable out and as you feed it back in.. put grease on the cable. If you do not have cruise, you will need to pull the cable off the back of the speedo and pull it through the firewall and then grease.
Old Sep 16, 2001 | 12:25 AM
mark79,80's Avatar
mark79,80
Have found bouncing speedometers to be due to the cruise control
transducer mechanisim binding. To check for this, remove the lower
speedometer cable at the cruise control transducer. Turn the fitting
on the transducer where the cable attaches. If there is a lot of
resistance, then the transducer needs replacing.
Rebuilt transducers can be ordered from Napa and Parts Advance.
Also available from many of the corvette suppliers.
Old Sep 16, 2001 | 01:15 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: ??? speed odometer is bouncing around??? (mark79,80)
Ditto --- same problem, same solution.
Old Sep 16, 2001 | 07:58 AM
Bills17n72's Avatar
Bills17n72
Hey guys
My 79 is a cheapy, I dont have cruise control
thanks Bill B
Old Sep 16, 2001 | 07:18 PM
Vader953's Avatar
Vader953
Default Re: ??? speed odometer is bouncing around??? (Torcher)
Mine did the exact same thing for a few months, and then quit working all together. Trust me, it IS the spedo cable. Either grease yours or get a new one. I suggest going ahead and getting a new one because they're not that expensive. I guarantee it will fix the problem. And since you dont have CC, it will be even easier!
Good luck. And don't worry, the money spending is a continuous process. What a money pit. My car was running perfectly, and all of a sudden today the tranny wont go past 1st. I'm scared poopieless and don't have money to get it fixed. I only hope it's not the tranny :U
Old Sep 16, 2001 | 09:51 PM
Bills17n72's Avatar
Bills17n72
ok guys
Im gonna go get a new speed odometer cable ,im sure the one in the car now is a little tired!!!!!
thanks for the help Bill B
To ??? speed odometer is bouncing around???
