upper trailing arm bushing
Old Oct 7, 2006 | 10:55 PM
mechaniac's Avatar
mechaniac
Default upper trailing arm bushing
Hey all!
just got my vette back together and now I have a new problem.. The upper trailing arm bushing on the pass. side is gone..
I was wondering if there was anyway to replace this bushing without a major disassembly of the suspension. Has anyone ever just dropped the front end of the trailing arm and pressed in the bushing under the car? Every suspension shop is weary of working on these years for pita problems and all the parts that break or corrode and will need to be replaced.
I just want to fix it and will go back and do a complete rear suspension rebuild in the future. I just put a 330 hp 350 in it and would like to enjoy it before it gets too cold.
Thanks a million!
Mechaniac
Old Oct 8, 2006 | 12:21 AM
SIXFOOTER's Avatar
SIXFOOTER
yea you can do that. I am assuming your talking aout the control arm. Put the front up on stands, block up the lower control arm, seperate the upper ball joint, unbolt the control arm
Old Oct 8, 2006 | 09:12 AM
Glassbowtie77's Avatar
Glassbowtie77
I believe he's talking about the rear suspension, not the front. The rear is a PITA to do compared to doing the the front end. Most cars have had the front end apart at least once in there lifetime and should come apart fairly easy, where as alot of these cars have never had the rear susupension apart and there is more of an issue with rusted parts such as bolts breaking and during disassembly. Be prepared to have plenty of PB Blaster on hand.
Old Oct 8, 2006 | 11:42 AM
mechaniac's Avatar
mechaniac
Yes I am talking bout the rear suspension. I was hoping I could buy the bushing tool, loosen the rear suspension or remove some of it and just bring the mount down low enough to press in the new bushing assembly, push back up into location, shim it and bolt it up. Any suggestions would be helpful.
Any one ever try a quick not to invasive repair like this?
Thanks!
mechaniac
Old Oct 8, 2006 | 02:15 PM
Vette Gator's Avatar
Vette Gator
I would think that it would be possible to do this, but getting the TA bolt undone is usually the hardest part of the rear suspension disassembly. Once this is out, the only other significant bolts that have to come out are the shock mount and spring bolt. I had to whack pretty hard with a big hammer to peen over the TA bushing pin while it was in the tool, and I think it would be more difficult to do this if the pin is parallel to the ground than if you can lay the TA flat on the ground. Your call, though.
Old Oct 8, 2006 | 03:40 PM
chris73cpe's Avatar
chris73cpe
once you get the pivot bolt out you're more than half way there as far as removing the arm is concerned. The shock mounts can be a real pain, but you might be able to remove the strut rod bolt at the center bracket and pull the whole thing out that way, replace the bushing, and put it back in. I personally wouldn't want to take out the pivot bolt with the spring still attatched, but others may disagree. If you're putting in new rubber bushings I think you're still gonna need a press to do it right anyway.
Old Oct 8, 2006 | 04:28 PM
Vette Gator
Originally Posted by chris73cpe
The shock mounts can be a real pain...
If you have access to a machine shop, you can take some 1" steel rod and drill and tap this to mach the shock mount thread. Make sure that the end of the rod rests on the "shoulder" of the shock mount and use the BFH to knock it out. Corvette Central sells essentially the same tool if it's not easy for you to to make it (or have it made). Don't beat on the end of the shock mount directly with a hammer or you will be buying a new shock mount. Don't ask me why I can say this with great confidence.
Old Oct 8, 2006 | 06:44 PM
chris73cpe's Avatar
chris73cpe
I used a gear puller to push mine out after lots of soaking in PB blaster, there have been a few threads already on different techniques for this, but if you don't want to deal with any major rebuild stuff right now I'm saying just disconnect the strut rod from the center bracket and take the whole trailing arm with strut rod to the workbench or machine shop and change the bushings there. Those cam bolts can break pretty easily too, but they're fairly cheap to replace and not too hard to extract(most of the time)
Old Oct 8, 2006 | 06:55 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Or you can go to the hardware store and buy a 3/8" NPT pipe cap...mine cost less than $1.
Old Oct 9, 2006 | 12:38 AM
mechaniac's Avatar
mechaniac
Thanks guys!
Gives me a direction and hope.. Couldn't ask for more unless..somebody wanted to come over and do it for me...but what are the chances of that right..
Thanks a million!
Eric
Old Oct 9, 2006 | 08:56 AM
SIXFOOTER's Avatar
SIXFOOTER
I would just go ahead and remove the Trailing Arm to do this, no good reason to try and wrastle this thing around under the car. Like someone posted above the TA Pivot bolt is the hard one, after that its just a shock mount, u-joint and spring bolt. If the lower shock mount is stubborn take it loose at the top.
Old Oct 9, 2006 | 11:28 AM
mandm1200's Avatar
mandm1200
I don't think there is an easy way out. There have been numerous times when I tried to take a different approach to do a job and wind up removing the item the way it should be. All I did was spin my wheels and waste time.
If you are able to replace it by removing only a minimal amount of components, the better off you'll be. The more that is removed the bigger the job. The little things like a brake line fitting being rounded off add to the aggervation and expense. VB&P has a poly bushing kit that is easy to install for the front of the trailing arm. It does need to be flared but is done with a nut and bolt which they supply in the kit.
Old Oct 10, 2006 | 08:08 PM
mechaniac's Avatar
mechaniac
Default under car kit from VBandP!
Just thought I'd let you all know that I found a Polyurethane bushing kit @ VBandP that they claim can be done on the car! 59.00 and it comes with a shouldered bolt that will ferrule the ends of the bushing pin. I should have it in in a few days and the opportunity to work on it in a few weeks. I'll let you know how it goes. I sure hope it works..I may do both sides now if it works like they claim..
Thanks to all for your responses.
Eric
Old Oct 10, 2006 | 08:10 PM
mechaniac's Avatar
mechaniac
Default part number
here is the part number or product I.D. if anyone wants it..
Product ID: 41043
To upper trailing arm bushing
