Got my car back from being worked on. I had the rear spring replaced, differential cover replaced, differential cross member replaced and replaced the gas line. The car has had a little spudder when taking off but I just figure that it is the carberator that needs to be rebuilt. Now when I am going about 55 mph and mash on the gas, it feels like to car wants to die. I let up off the gas and it takes a few moments for it to repsond again but I have to press on the gas very slowly before it responds. The car idles good and when I gun it whiile it is in park, it seems to be responding good and the secondaries do kick in. It is when you put a load behind the engine when it does this. The car worked good when I took it into the shop. I was thinking that fuel pump might have got some dirt in it from the gas old gas line or maybe the float in the carberator could be stuck.
Does anyone have any idea what might be going on? Plus, where is the build sheet for the car located. It was not on top of the gas tank when they dropped it. They did say there was a shield above the gas tank and it could possibly be there.
This is a 75 L-48 Q-Jet. Is there a way to test to make sure I am getting enough flow through the gas lines?
Flow, I dont know, but you can check the pressure but it will most likley require cutting the steel line from the fuel punp to the carb.Replacement lines are still available. I would change the fuel filter first.
I would also contact the shop that did the work and ask them what happened
Ran fine when you bought it in, now it runs like crap?
Not acceptable in my book
there is a certain amount of fuel necessary to cross the 1/4 mile in a certain time frame. If your not pumping that amount your carb bowls will run out of fuel before that time frame.X amount for a 10 second car.X amount for a 12 second car etc I don't remember the figures and i can't find my chart. If someone else doesn't have that info i will look around the shop tomorrow. Anyway your pump should pump X amount of fuel in a minute to be acceptable to maintain fuel to the bowls during operation. Take a measuring device larger than a cup and put your fuel line closest to the carb into the cup and have someone turn the car over for 10 seconds and see how much you get in the cup, take that number and multiply it X 6, that will give you the amount your pump is pumping per minute.If there is a restriction u know its between tank and carb.Possibly a faulty fuel pump. I think u said u have a Q-jet so i'm guessing your filter is at the carb. So this test won't tell you if your filters bad.
when you say "replace gas line" which line are you talking about? tank to fuel pump, fuel pump to carb, return line, etc. ??? sounds like a fuel starvation problem and since they worke on the "gas line" i'd start with that.
here are the figures for amount of fuel necessary to complete 1/4 mile run in a particular time frame. U can use this to determine your problem.
You must fill a 1 gallon can in this time frame using just your fuel pump to run a particular time thru the 1/4:
12 second car it should take less than 35 seconds
11 second car less than 30 seconds
10 second car less than 25 seconds
9 second car less than 20 seconds
8 second car less than 15 seconds
7 second car less than 12 seconds
that can be used as a guide to see the state of your fuel delivery system, also it should maintain 6-7 psi pressure
So you are saying that HP, gearing ect: does not have any effect on your formula?
The guy has a stock L-48
No offense but where are you trying to go with this thread
He has a sputter and what sounds like either starvation or a improperly set secondary air valve, or many other possible problems...timing, vacuum ect:
Sorry but I dont think the quanity of fuel to run a measured run in a certain time frame has anything to do with his problem at hand other than making it much more confusing to diagnose......
The main fuel line and vapor lines were replaced. I took out the fuel filter to replace but I have the wrong one. The one I have is about 1/2 the length of the one that is in there. I blew through the original filter and it seemed to flow good. Just out of curiosity, what is the inside diameter of the main fuel line supposed to be? They replaced it with a plastic fuel line and I am wondering if the inside diameter might not be large enough to carry the volume of fuel needed.
My buddy who brought it home for me said it seems like it is getting worse. He test drove it yesterday for me because of my knee. I thought maybe it didn't have enough gas in the tank so I filled it up and it still spuddered pretty bad.
It sounds like the problem mine had and it was a pinched gas line. I am not sure if they replaced the fuel lines from the tank to the frame, but if they did they would have dropped the tank. My rubber lines from the tank to the frame were crossing and pinched and that was the cause of my fuel starvation. It acted the way you describe for a while (approximately 3 months) and then started to get worse and worse until the car would no longer start.
The other line to watch is from the frame to the pump. Regular hose would not make the "S" without pinching itself off. A molded hose is available for this application. Good luck.
so your telling me that if his car running 14's should take 45 seconds to fill a gallon jug by pump, and it actually takes him 2 minutes to fill that jug won't indicate he has fuel starvation issues and he can apply that same figure to test before and after different component tests in his fuel system isn't logical? it's only a figure to give him an idea given by a professional carburetor manufacturer. It may be confusing to alot of you. As i'm just an amateur at this whole game i'll shut my hole
thrilher
It is confusing to me and I maybe the one that is way off
By no means did I ask you to :shut your hole"
I would like to learn more about your theory as I am an amatuer as well
no man i reread his post, i thought he replaced his rearend ..i see the fuel line change too...i just did the test for the sake of it while replacing my carb, it was fresh on my mind and would be a two step method with recordable results..i really am an amateur i wasn't being sarcastic. and yuo were right i was probably complicating a simple troubleshoot...no problems here man
I finally think we have it fixed. I know it has been a while but I have been having some problems with my knees that prevents me from getting on floor to look over the fuel line to check for pinching or even doing anything that might seem simple to others.
I replaced the fuel pump and noticed a real small kink up by the fuel pump. I added the S hose to relieve that kink and that didn't fix the problem. I got an Edelbrock carberator from a friend up the road several weeks ago that came off a 70 or 71 Camaro 350. While standing around the car the other night, my step son came over and we decided to go ahead and change out the carberator. We had to make a few modifications, get some parts, but now the car sounds like it is running strong.
He put the carberator on yesterday afternoon while it was snowing outside. Now I can't wait for the snow to get off the roads so I can take the car out for a test drive. We did do a small brake torque yesterday and it didn't die out like it did before. I guess the Quadra-Jet is a real Quadra-Junk.
Thanks for all your ideas on trying to help resolve my problem.
No offense, but that statement is only made by people that do not know enough about them or how to tune them. If you ask many people on this forum, a Q-Jet can support upwards of 400hp when done right.
I don't mean to offend anyone. It all depnds on who you talk to I guess. That is the original carberator and has never been rebuilt. I have the rebuild kit so when I get some time, I'll go ahead and attempt to rebuild it as a back up for later.
Change the fuel filter that is in the carburaetor inlet...this is my bet for the whole problem.
I have a tank from a '74 in my '69, when I got it from the parts car the tank sticker was right on top...but almost dust. That is where it should be, if not there, pretty slim chances of finding it elsewhere (although it reportedly has happened).
