tranny question
Old Oct 9, 2006 | 02:22 AM
Enersis's Avatar
Enersis
Default tranny question
Well im about to put in a 383 stroker with 450 hp, and a few poeple told me the stock th350 tranny wont hold up.
is this true?
also i bought a 600 cfm holly carb and was told bymy bossthat it will run the stroker fine.
is this also true?
Old Oct 9, 2006 | 03:13 AM
Graemeinvette's Avatar
Graemeinvette
I'm sure others here who are better informed will chip in but I would have thought that a 600cfm carb would be on the small side for a 383 stroker. I have a 350 putting out 430hp and have an 800cfm carb on it.
Old Oct 9, 2006 | 03:49 AM
Enersis's Avatar
Enersis
hmm alright.
thats upseting, i work at a auto parts store and my bozz said the 600 would be fine on the 383, so i bought it and stuck it on my 350 for now.
so i guess i will have to buy another carb
Old Oct 9, 2006 | 06:54 AM
windsoreight's Avatar
windsoreight
Carb is going to be too small. You will most likely need a 750. As far a trans if the th350 is in good shape it should hold up. A th350 will hold up to your engine it will just depend how much time yours has left.
Old Oct 9, 2006 | 09:47 AM
slowup's Avatar
slowup
yea carb is waaay to small. I have a 750 and it works fine for my 383.
Old Oct 9, 2006 | 10:09 AM
Ganey's Avatar
Ganey
Normally 600 VS are used for mild 350s.
Which Holley 600 & what's the intake? AFR did a 383 w/ a Holley 600 DP w/ about 420 HP.
So far it sounds like a 650 DP would be better for your setup or 750VS.
Old Oct 9, 2006 | 11:06 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
is this true?
is this also true?
I ran a big block 427 pushing 500 horses with a Turbo 350 and had no problems. Just make sure it's in good shape. I have a 383 stroker in my 61 with a Speed Demon 650 double pump. It feels a little under carbeurated. I would go with a 750. You will enjoy that stroker. They are stump pullers.
Old Oct 9, 2006 | 11:12 AM
Enersis's Avatar
Enersis
thanks guys
To tranny question
