alarm system help
Old Oct 9, 2006 | 02:46 PM
ctrain22's Avatar
ctrain22
Default alarm system help
I am trying to get the factory alarm system working on my 70 convertible(along with every other system). While cleaning out the rear storage compartment, I found the harness with nothing connected to the terminals. One is a three prong, the other two shaped like a flasher terminal. Also found a two more connectors that I believe go to the glove box light. I think the two connectors are for the alarm. One thread I read mentions one is for a flasher to work the horn and the other is a realy. I ahve been looking for the relay in the vendor parts catalogs, but no mention of an alarm relay. It is a special relay, or dose a relay for something else get used for the alarm also?
Old Oct 9, 2006 | 04:35 PM
Duke94's Avatar
Duke94
On my 71', the relay and flasher are on a bracket fastened to the front of the pass side storage compartment (where the jack stores). AIM calls out P/N 1115878 for the relay and 3904868 flasher. Hope this helps.
Old Oct 9, 2006 | 10:22 PM
ctrain22's Avatar
ctrain22
Pardon my ignorance, but what is AIM? I heard of it before, but don't know what it is. I am sure it's doesn't mean AOL Instant messenger. Do you know where I could get the relay. The flasher is readily available and our vendors, but can't seem to find the relay.
Old Oct 10, 2006 | 11:26 AM
Duke94's Avatar
Duke94
The AIM is the assembly instructions GM used at the assembly plant and shows how to put the car together. VERY USEFUL.
http://www.zip-products.com/Zip/prod...DEDBE6B6663DB8
You will have to search eBay for the relay as I haven't seen them in the Vette parts catalog either, or see if anyone has a good used one. There maybe be a "functional" replacement for it.
Old Oct 10, 2006 | 01:40 PM
ctrain22's Avatar
ctrain22
I kind of figured it was the assembly manual, but the "I" in the AIM was confusing me. Does anyone know where this relay can be found?
Old Oct 10, 2006 | 02:17 PM
Duke94's Avatar
Duke94
Here's a post from a while ago on the alarm system relay.
http://forums.corvetteforum.com/show...p?p=1557033501
Here's the horn relay referred to in the post. Might be worth trying.
http://www.corvetteamerica.com/cf/di...ord%3A%20relay
To alarm system help
