Auto trans...flexplate runout
[Modified by Jvette73, 5:34 AM 9/17/2001]
Norval
1. GM flexplates quite often fail with mileage/age. Sometimes when they crack out, because they are allowing the comverter (which, in this case, weighs 38lbs. dry) to run eccentrically, a vibe will be felt. Yes, sometimes the vibe comes and goes with rpm's. Look for cracks right around the bolt circle area where it bolts to the crank.
2. The pilot of the converter could be worn. No, I'm not kidding. The pilot of GM 298mm converters (sized at 1.703") has very little bearing area. As in works back and forth in the pilot hole that it sits in, it can become flat spotted on one side. If, when putting it back into service, the converter just happens to be placed into the pilot hole with the flat side down, you end up with the converter running eccentrically. This = vibes.
Sooo . . . unbolt the converter, then index it around so that the pads line up with the next set of bolt holes. Which is to say, give it 1/3rd of a turn, then bolt it back up.
With any luck, you are no longer centering the converter on the bad part of the pilot. If it runs true now, the vibe will be gone.
If the vibe is still there, do the index trick again. Be sure to do it in the same direction in order to make use of a " new" section of the pilot.
3. If you still have vibes, do a variation of #2 above.
It is possible (but not too likely) that the pilot hole itself in the crank is out of round. As the old converter worked back and forth, it could have worn the bore slightly on one side. Due to bad luck, you may have set the converter pilot into this bad spot.
Unbolt the converter. Now - without rotating the converter - index the flexplate so the next set of holes lines up. Yeah, it sucks because you need to turn the motor 1/3rd of a turn, but there is no avoiding it.
Now you may have a good section of the pilot hole to work with. If the vibe is still there, once again index it another 1/3rd in the same direction to get a "new" part of the bore to work with.
If 1, 2, and 3 above don't do the trick . . . take the coverter back and exchange it for another, it has been built in an asymetrical fashion and/or it is out of balance --> it is NFG.
[Modified by 45ACP, 9:48 PM 9/17/2001]
