upgrading to HEI from Coil
Old Oct 10, 2006 | 08:09 PM
BigJim13 JR.'s Avatar
BigJim13 JR.
Default upgrading to HEI from Coil
HI,
i have a 74 and it has been upgraded to HEI ignition as opposed to the old coil.
now with this upgrade, is there more to it than just putting in an HEI distributor??
the car used to run perfectly when we had first started it now after i replaced all the brake lines (car sat for about a month) it has decided to be hissy when starting.
it wants to just click at us however although the battery was low, it does not seem low enough to cause this. it should at least be turning over instead of that clicking..
also is it possible that somehow the battery could be draining??
THANKS
JIM
Old Oct 10, 2006 | 09:44 PM
SIXFOOTER's Avatar
SIXFOOTER
If its just clicking instead of turning over, it can only be a couple things. Battery, Battery connections, ground connections, starter.
I would inspect all the battery connections, charge the battery (with a real battery charger) and see what you have.
Once it does start, verifying battery drain is a good idea, it will require an amp meter which you will place between the Pos terminal on the battery and the Pos battery cable. Yould should measure less than 100 Miliamps. If it is more, someting is wrong.
Old Oct 10, 2006 | 10:28 PM
BigJim13 JR.
okay,
just to verify
disconnect the positive battery cable and take a reading from the positive terminal to the positive cable and it should be less than 100 miliamps
THANKS
Jim
Old Oct 10, 2006 | 10:59 PM
crazywelder's Avatar
crazywelder
Are you using the old coil wire to power the HEI? If so, it will work for a short time and quit because it is a resistance wire. You'll need to run a 10ga wire from the pink wire at the ignition switch to the + terminal on the distributor. This will provide the correct current to operate the HEI from the same connection point as the factory. Make sure to solder and shrink tube the splice at the pink wire.
You can purchase the distributor connector from Summit or a kit with wire and connectors from....http://www.madelectrical.com/
Old Oct 11, 2006 | 10:39 AM
BIGJIM13's Avatar
BIGJIM13
Hi
when you say..
"run a 10ga wire from the pink wire at the ignition switch"
can you be more specific...as to where to get to this pink wire?
Old Oct 11, 2006 | 10:46 AM
wfo76's Avatar
wfo76
On the points system, there are two wires to the coil. One (from the fuse block) is a resistance wire and only gives 9 volts to the coil. The other (from the starter) gives a full 12 volts to the coil but is engaged only during engine start. You want to eliminate the wire from the starter and the wire from the fuse block needs to be changed to a standard wire to give the full 12 volts to power the HEI correctly.
Old Oct 11, 2006 | 10:52 AM
BIGJIM13's Avatar
BIGJIM13
HI
no points! converted to HEI! trying to find out where is the best place to get power to go to the + on the distributor! Willcox suggested the starter...was trying to find out where on the starter!
Old Oct 11, 2006 | 11:29 AM
wfo76's Avatar
wfo76
I realize that just trying to explain the two wires that were originally used to help you figure it out. Can't use the starter because as soon as you release the key on startup the engine will die. Starter wire only used with points and only helps engine to start. Once the engine is running that line goes dead. Must use the wire coming from the fuse block. This was the original coil wire and should still be there. Measure the voltage on it with the ignition ON and it should be about 9 volts. Replace this resistor wire with a standard wire and you will now have 12 volts available to power the HEI.
Old Oct 11, 2006 | 11:41 AM
crazywelder
The pink wire is located at the ignition switch at the lower section of the steering column. You want to splice into the pink wire with an additional 10ga wire that will be routed to the + terminal of the distributor. This is typical for any older GM vehicle conversion to HEI.
To upgrading to HEI from Coil
