Long vs. Short Water Pump Identification
Old Oct 12, 2006 | 08:25 AM
skydaddy's Avatar
skydaddy
I figured he meant the K&N filter with filter top.
I posted links to them above
Old Oct 12, 2006 | 09:14 AM
Durango_Boy's Avatar
Durango_Boy
All these issues with having or making sure you don't get the wrong water pump is one of the reasons I made sure I switched to a factory style SBC serp system. It has a specific water pump and only comes in one length. The single serp belt lines up every time, and I'm even deleting two accessories and adding one. It all lines up. Gravy.
Old Oct 12, 2006 | 01:57 PM
asianlimodriver's Avatar
asianlimodriver
Thanks for all the input. I didn't plan on changing out the water pump, just the pulleys and all the accessory brackets. I'll guess that I'll just have to pull them all off and take them to the speed shop to match them up with the new parts. As for the air cleaner top, the K&N filter top is just what I was looking for. Now I just have to figure out what manifold and carb setup I can run under the stock small block hood on my 72.
Old Oct 12, 2006 | 02:17 PM
Durango_Boy
Would a '72 clearance be about the same as a '77?
Most intake and carbs will fit so long as you use a drop-base air cleaner.
Old Oct 12, 2006 | 09:15 PM
71rdster's Avatar
71rdster
No. You have one or two more inches in height on the 77 hood over 72 small block hood. Compare.
http://100megsfree4.com/corvette/1970/1972/72green1.jpg
http://100megsfree4.com/corvette/1970/1977/77black1.jpg
Old Oct 13, 2006 | 11:03 AM
Durango_Boy
In that case a good low profile manifold is need, plus a drop base air cleaner. I have a Weiand manifold on my Vette right now that is VERY low profile. I had a standard air cleaner originally and had plenty or room, tested with a bar of clay. I wanted a taller filter, so I switched to a drop base. Not only that but I like how they look hugging the engine a little.
Anyway, call a few paces or surf catalogs. They will usually say if it fits a Corvette of your year in most product descriptions.
Old Oct 16, 2006 | 09:49 PM
VCuomo's Avatar
VCuomo
Asianlimodriver - sorry it took so long to respond to your request! Here's what the Endurashine products look like:
Old Oct 17, 2006 | 12:19 PM
Durango_Boy
I like the frame notch and patch down there. Very pro job man.
Old Oct 17, 2006 | 12:41 PM
VCuomo's Avatar
VCuomo
Thanks for the compliment man! :o
But... frame notch and patch? The frame is stock...
Thanks again!
Old Oct 17, 2006 | 12:52 PM
Durango_Boy
Thanks again!
Sorry, it looks like it's been cut out for crank pulley clearance, and patched inverted. Guess I missed that one.
Old Oct 17, 2006 | 04:37 PM
Binnie77's Avatar
Binnie77
VCuomo: Awesome looking engine :-) Where did you get the brackets and holders for your wires? They look sooooooo neat :-)
Old Oct 17, 2006 | 05:12 PM
asianlimodriver
VCuomo, that is just gorgeous!!!!! Don't tell me that the motor fits under a stock hood! I was wondering, what type of headers are you running? It looks like their shorties in one of the pics.
Old Oct 17, 2006 | 05:24 PM
  #33
asianlimodriver
Old Oct 17, 2006 | 08:51 PM
  #34
VCuomo's Avatar
VCuomo
Binnie77 - I got them from Santa Ana Speed Center in Santa Ana CA. Unfortunately, I don't remember who makes them.
Asianlimodriver - Thanks! The motor doesn't fit under a stock hood - I purchased an aftermarket L88 hood. The shorties that you spotted (good eyes!) were only used while the engine was on the stand so that I could run the spark plug wires (each wire is custom cut-to-length). The engine is now installed in the car with ceramic coated Hedman headers (you can see the driver's side header in the last photo above). Here's a shot of the front of the car so you can see the hood better:
Old Oct 18, 2006 | 09:48 AM
  #35
Durango_Boy
I too just got my L88 hood, and it's great to see painted hoods. I can't wait to see mine in shiny new black. I didn't have clearance problems yet, but now I have the option to go taller without fear of hood clearance as the hard part is done.
Old Oct 18, 2006 | 01:21 PM
  #36
asianlimodriver
Vcuomo,
You must live pretty close to me. I'm in Norwalk, Ca. and work in Cypress. Do you ever go to any local events? Car shows, Pomona Swap Meet?
Old Oct 18, 2006 | 02:26 PM
  #37
VCuomo's Avatar
VCuomo
Every now and then a buddy and I go to the Pomona Swap Meet - we should meet there next time we go. My buddy and I usually drive our Corvettes (he's got a BB '69) and park in the "classic car" section.
To Long vs. Short Water Pump Identification
Old Oct 18, 2006 | 11:52 PM
  #38
Durango_Boy
VCuomo - I've been looking at my L88 hood, and sorry for the hijack everyone, but I was wonderign about that dip att he front. Do you find it collects water or have you even ever had it out in the rain? If it did I was thinking of designing some kind of a drain tube that could be routed through the engine bay down to the ground or something.
Old Oct 19, 2006 | 12:38 AM
  #39
onaqwst's Avatar
onaqwst
vc,
this the place for the cog drive kit
http://www.blackmountainprecision.co...mall-block.htm
i was looking on the 1" kit with p/s
but i need brackets for alt and ps pump
b
Old Oct 19, 2006 | 02:51 PM
  #40
VCuomo's Avatar
VCuomo
Durango - I don't drive my 'vette in the rain, but yes it definitely collects water. My buddy's '69 hood has a small hole drilled at the front "point" of the hood (I assume this is "stock", but it may not be). And, if you use an electric fan instead of the stock fan, I think the water would drip out of the hole and miss everything except the frame's front crossmember.
onaqwst - I bought my kit from Santa Ana Speed Center (714-835-6424), and I think that right now they're the only distributor for this particular belt drive kit. They also have the PS pulley that will line up and the alt bracket that works. Also note for this kit that you'll have to use a "standard" water pump (not the Corvette-specific one). Edit: On second look, that link does appear to have the same belt drive as I have. And it also looks like you can use either short or long shaft water pump, depending on the kit you order. But you might want to give S.A. Speed a call - I think their price is less than Black Mountain.
