Stripping body
As for the stipper, I could never get a strait answer, so I used the weak stuff and didn't let it get down to fiberglass..
use a proper stripper designed to be used with fiberglass and it's perfectly safe as long as you follow the directions and wash the panels afterwards.I've had both of my vettes painted and both cars were stripped down the bare fiberglass using chemical strippers with no problems or issues afterwards associated from the chemical strippers.
Everyone has their own opinions or preferences in stripping methods but personally, chemcal stripping is the only method I will ever use. it's the least risky as far as damage to the body is concerned.
razor blades can nick and gouge the body requiring repairs before painting, sanding can be overdone rounding off the sharp feature lines of the body, and media blasting can easily destroy the body completely if not done with the right media or by a technican not used to working with a Corvette body.
I'm not saying the other methods can't be used and each of them have been done successfully by people on here, but they inherently carry a greater risk to the body requiring repairs afterwards than chemical strippers do.
On the other hand, chemical stripping is very, very messy and not fun but in *my* opinion it's the safest method and the only one I'll ever use on my Corvettes.
BTW, my painter specializes in older Corvettes (C1, C2, C3 cars only) and has been doing it for over 30 years and he only strips by chemical strippers and has never had problems. One of the key steps he uses besides thoroughly washing each panel after stripping it, is that he lets the car sit for a minimum of two weeks without touching it before proceeding onto the next step of any body repairs, or priming, or anything. This sitting period allows any possible remaining chemical stripper than may still have remained after washing to "vent" out of the fiberglass.
http://mywebpages.comcast.net/vettfixr/page9.htm
I just used Capt. Lee's, and it worked great! There was 4 layers of paint and it ate right through it. Good Luck The Best of Corvette for Corvette Enthusiasts
I will be finishing my paint over the winter. Let's keep the paint prep strings coming!!!
-Charlie
I have linked to this many times in the past and I still feel it is the best way to prep and paint a Vette.
yeah, i got some knicks and scratches. just a little filler... for me it was a matter of convenience.
when your done you can sweep up all the flecks of paint & save them in a brown bag....
You'll still have the origional paint!!!
