Control Arm Removal
Any suggestions, I'd really like to get it out to do the work on the control arm while it's off the car.
RGVette
By the way I searched the forum for "Removing Stuck Bolts" and there is great advise in there that I and many of you can use to remove a stuck bolt.
RGVette
Batman's correct, air is a great resource, and a good air gun is easy to get at Lowes, Home Depot, Wal-Mart, Ace, and so forth. It's either impact or heat...
Also it just dawned on me that the female companion that the bolt is going through has no threads. Would that mean I could use a puller or a pusher?
a pusher?
12''= Regular sized 1/2 inch ratchet. breaker bar will be 18+''. Just find a nice heavy walled pipe to slip over your bar. Very possible you break the head off. I HIGHLY suggest www.kanolabs.com Aero kroil. Much much better than PB blaster or other oils. Expensive for a reason and it doesn't take very much of it to work.
PS: You live anywhere near I-80? In a couple-four weeks I'm heading that direction for a job. I'd like to check our your project! If ya don't mind having a punk kid over. lol
Explain this a little bit please. The three bolts that hold up the cross bar all have a companion. The two to the front have a rectangle block with threaded holes. The back side that has a single large bolt has a nut on the bottom when you;re looking up, and the bolts threads down from above with nothing to hold it from spinning.
What is it that doesn't have any threads?
I ran into the same issue. The large bolt for the lower control arm shaft
was rust-seized to the shaft itself. We tried many methods:
breaker bar (bent extensions), brass hammer (not a budge), and heat (still no-go).
These are the methods I would try first (and sounds like you did or will).
See all the smoke here :
http://NHvette.com/ftp/in/pra4sun_01.jpg
It was fairly safe if the torch was pointed properly:
http://NHvette.com/ftp/in/pra4sun_02.jpg
Finally, I decided to try using a 2-jaw gear puller to push the bolt up.
Sadly, the edges of the bracket are rounded enough that the puller would not grab.
Well, Dennis had to leave his vette with me that weekend.
I took some time that eve and built a little tool to help make the puller work.
It is basically a small rectangle of 3/8" steel with a foot welded to one
end and a stud on the other end. You lay the tool over the bolt head,
with the stud fitting into the bracket hole and the foot sitting on the
trailing edge of the bracket. Then, a gear puller hooks onto the tool
and the treaded rod of the puller is used to push the bolt through.
It took lots of pressure and hammering on the puller to get it moving,
but then worked it out slowly.
Keep at it with the ideas already presented ... might work loose.
If you reach your wits-end, then send me an email dave@NHvette.com .
I will let you borrow the tool I made ... if you promise to send it right back.
Damn ... just realized that I will never be able to use it on my vette with frame gussets.
http://nhvette.homeunix.com/ftp/in/front_gusset_07.jpg
Funny ... I actually had the same deal on one of the steering knuckle bolts.
I broke my nice Craftsman 6-point 5/8" socket when I slipped
the pipe over the ratchet for more torque. Finally got it with
an impact socket.
By the way when you torch it you torch the surrounding shaft, right?, and not the bolt itsself?
I really appreciate, I've said it before and probably will again, the suggestions you all give on this forum.
OK, off to get an impact socket
How you described it is correct. The one I have already taken out on the other side is just like that.
Of course for the real stubborn stuff, an impact gun is your best friend.
Impact sockets + very long breaker bar + 500 lbs of arm torque = END OF LIFE FOR STUBORN NUTS AND BOLTS. Good luck.
