Changing a Auto to a Manual your help
Old Oct 13, 2006 | 09:17 AM
Jims79's Avatar
Jims79
Default Changing a Auto to a Manual your help
I know I read this before but could find the thread. How hard is it to chg an auto to a 4sp car. Other then buy the 4sp do I need a donna car to get the hardware out of like pedals, linkage etc. and is it a easy swap. What needs to be done to the engine, carb etc. Do I need a new bell housing? & last what kind of money are we talking about here?
Jim
PS the reason is I see more good buys on old auto vette's then 4sp
vette's and I maybe buy a auto but would want to chg to 4sp
Old Oct 13, 2006 | 09:38 AM
problemenko's Avatar
problemenko
Jim, I'm in the process of changing a 79 auto to a 4 speed. Bring your check book. Keisler and others sell complete kits with 5 and 6 speed options that are expensive. I picked up a completely rebuilt Saginaw from a circle track racing company in Wisconsin for under $500. You can specify the gearing and the internals are hardened and clearenced for racing purposes. That was the least of the cost. You then need all the other stuff that will run around another grand or so. Then's there is all the work. I think it's worth it.
Old Oct 13, 2006 | 09:46 AM
Jims79's Avatar
Jims79
Thanks you should start a thread or jump on this one w/your progess. I would like to read your step by step & see pic's of all the work. It would be great as a guide for other members. Thanks again Jim
Old Oct 13, 2006 | 09:59 AM
Binnie77's Avatar
Binnie77
http://www.corvettec3.ca/tko.htm
Old Oct 13, 2006 | 11:20 AM
Durango_Boy's Avatar
Durango_Boy
Batman is changing his '77 auto to a manual, a T5 I think, and he just found his pedals on Ebay. He's getting it done pretty cheap minus the cost of the manual chosen. I think the car is already set up for it minus the linkages and pedals. Another cool idea when doing this swap is a hydraulic shift assist. Do a search and you'll find a lot of cool info on this.
Old Oct 13, 2006 | 12:16 PM
Jims79's Avatar
Jims79
Originally Posted by Binnie77
Wow everything you need to know and then some. Perfect thanks
Old Oct 13, 2006 | 12:19 PM
Binnie77's Avatar
Binnie77
I have lots of new parts left over from my change over including a new flywheel and lots of linkage parts. IM if interested.
Old Oct 13, 2006 | 12:27 PM
BerniesVette's Avatar
BerniesVette
I swapped my 79 auto to a T5 5 speed overdrive for $1,200.00. I went with a hydraulic clutch which is easier to install and a lot smoother and lighter than one with linkage. I would not hesitate to do it again! It is the best mod I have done to my 79!
Bernie
Old Oct 13, 2006 | 09:07 PM
Durango_Boy
Bernie
Thanks for all the info Bernie. I hope you don't mind me copying all the info, pics, and links. I have it all archived away for a future swap. I know using just the info from this thread that ANYONE can do a hyd clutch swap painlessly. Thanks so much man.
Old Oct 14, 2006 | 10:30 AM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
I did it to my 76. If your car is after 75, you'll have to cut the steel tranny hump. I purchased the factory lower rubber boot that seals off the interior below the center console, and made a small patch panel to make it fit correct. Also, you'll have to install the clutch pedal. This can be done without removing the dash, but it's not fun ... you have to remove the steering column, several brackets, and remove the whole brake assembly out below the dash (took me a day to get it out and back in with the new pedals).
It definetely is worth the work, but if you go with the mechanical linkage here is a few tips that really helps the factory clutch linkage out: 1) get the Mr. Gasket chrome moly push rod #2478 2) install polyurethane motor mounts 3) if you want better pedal spacing, get good aftermarket pedals. The polyurethane mounts help because they have to react the force of the clutch on a mechanical linkage and the stiffer mounts improve the feel and reduce the movement in the linkage.
Other parts you'll need: bellhousing, center console plate, and you'll probably have to modify your crossmember.
Old Oct 14, 2006 | 03:37 PM
BerniesVette
Durango,
That is what the forum is for. If you have done it, help someone who hasn't. I'm just passing on all the help I have received!
Bernie
Old Oct 14, 2006 | 06:57 PM
Durango_Boy
Durango,
Bernie
I know what you mean. I have about five papers I want to write, detailing all themods I have done and how I did it. Then when someone asks all I have to do is post the paper, and give them the help without a lot of searching and mistake making.
To Changing a Auto to a Manual your help
