Differential Side Yoke Orientation ?
Old Oct 14, 2006 | 04:30 PM
RobRace10's Avatar
RobRace10
Default Differential Side Yoke Orientation ?
What is the correct orientation of the sides yokes on the differential? I believe they are supposed to be 90 degrees from each other, but as you can see mine is not setup that way they are probably 15-20 degrees off from a 90. The left yoke is vertical and perpendicular to the bench.
Old Oct 14, 2006 | 04:45 PM
gyopp's Avatar
gyopp
It really doesn't matter. When you are cornering the posi clutches will slip and let one axle turn faster than the other so the position of one axle relative to the other is always changing.
Old Oct 14, 2006 | 05:49 PM
Gordonm's Avatar
Gordonm
It makes no difference because where ever you put them the first corner will change the oreintation
Old Oct 14, 2006 | 05:51 PM
73-84 IMSA Widebody's Avatar
73-84 IMSA Widebody
Unless you have a locked diffy it will change
To Differential Side Yoke Orientation ?
