Hi, I am going to try to put a 383 sbc together. I have a unmolested 350 4 bolt block with a casting number 3970010. I am thinking of this stuff....what do you think?
Eagle 3.75 Forged Lightweight Crank #4350375057LW
Scat Pro Comp 6" I-beam Rods with 7/16" Cap screws
Calico CT-1 Treated Bearings
Childs & Alberts ZGS Rings
AFR Competition 195cc Heads
I am at a loss of what pistons to run, I just want to run Premium gas............any help?
Also, I don't know anything about Dampners, I think I want to go a little lighter than stock.
I'm going to run a smaller Solid Rollercam in the .225-.240 range.
This engine is going to be a street engine & I do understand the consequenses & maintance that goes into the Solid Roller. Thanks!
SRP makes some good reverse dome pistons that should put your compression ratio where it needs to be.
Out of curiosity, why a solid roller? They're generally considered all-out and pretty extreme and the cam duration numbers you're looking at won't let the engine get to the operating range where a solid roller will really shine. I don't understand why you want to go thru the PITA of a solid roller while running duration numbers that are easily attainable with a good hydraulic roller with MUCH less trouble and maintenance.
I read about those & they said they use a alloy that doesn't expand that much, might be good for what I want. And, I don't know if it's smarter to run a small cc head & reverse domes or to run a larger cc head & flat tops. I think I can get away with flat tops. It seems like the solid roller give you a wider power range by about 500 rpm. I want something that runs a little better than normal. And, I don't mind checking it, I think sometimes I don't know until I have been there! Thanks.
Smaller chamber and a reverse dome is the better way to go.
You might think about a solid flat tappet cam as well - they rev very well and are less maintanenance than solid rollers and you still get that sewing machine clackety clack that tells the world you're running a solid tappet.
SRP makes a great piston at a great price. Summit Racing has a newer line of dampers that are sfi approved and reasonable priced. $130 or so. I have seen them and they look decent.
I think you will get the best results with a flatop, zero deck .039 gasket, and the 74 CC AFR heads. Perfect quench, Better flame travel and efficiancy with the flatops and it will get you about 10 .2 to 1 which should get you in pump gas territory on your dynamic compression. Check the Mahle Powerpack line. Mine were within 1 gram out of the box and under $500. They are low expansion, Hi Silicon, forged pistons
Yeah, that sounds like the way. I could probably have the heads milled a little bit & get a little more compression. I wonder if the Mahle Pistons could be ceramic coated or would the finish they have on them be difficult to get off? Probably both things would not be worth it though?????
They come with a coating. The ones I used are a 4.030 piston W 6"rod, and 74 CC heads. Static compression 10.2 to 1. Cam is 236 int dur @ .50 and 244 Ex dur @ .050 W/ 114 LSA Dynamic comp 8.24. Max is 8.5 to run premium and it has to be extremely well tuned to avoid detonation. I think there is a ebay seller with these pistons for $469.
Yes. Just went through the same parts selection process and decisions you are going though now. We seem to have come to a lot of the same conclusions as well. Mine is still at the machine shop but the parts are bought and everything for the build is figured out. It's line honed, decked, bored balanced and ready for torque plate hone, clearancing and test fitting. Shooting for 500 HP plus 150 nitrous
That's the same train of thought I used - flat tops with larger chambers - but my engine builder did back-go-back tests and picked up about 12hp from going with the smaller chamber and reverse dome. He said something about the shallower chamber unshrouding the valves better. I don't think it's an item that's worth losing sleep over, though. Good luck, 383's can be made to increase the pucker factor many times over!
St. Jude Donor '03-'05-'06-'07-'09
Have to rebuild my all original 108 K 72 Vert. Planning on a Scat or Eagle 383 rotating assembly....lots of torgue.....which is great for my TH400 and 308 rear grear.....
Very Cool! 63 Mako, what's your machine shop bill going to be? Also, I think I know what deck height is, but, is "zero" deck height like a blueprinted number that production blocks are always over on?
I used some 12cc or so dish pieces with 62cc chambers, hydraulic roller 230/238 with TFS heads. Pulled like a mule! The vette is getting a big block, though - 3.75" stroke, 4.600" bore for 499 cubes with a 264/270 @ .050 solid roller and 320cc Pro Topline aluminum heads. That's where the "L88Plus" comes from - same stroke, same .050 numbers on the cam and aluminum heads, all similar to what is arguably the most famous and revered engine ever dropped between the frame rails of any Chevy. Other than that, mine is an aftermarket monster all the way. BOOOOYAAAAAY!!!
Sounds like a big improvement! I'm kinda excited going from a 190 hp 350, I think it will be a major improvement, everybody seems to like the 383 on the street. Thanks for you're help.
Machine shop bill is under $1000 till dyno time comes. I had a stock 1973 L82 block. The technology today for decking is way better than production line. Mine started about .025 from the piston top to the deck. When my ine was decked the shop sets it up and mills the first side exactly 45 degrees from center. down to 9" from the crank centerline. then it is turned 90 degrees and the other head mating surface is milled to 9", also parallel to the crank centerline. It could be argued that I could have gotten the same results by using a .015 shim gasket but the first pass only hit on the front outside corner. second pass cut the outer half of the deck surface. The deck cut was .008 by the time we were cutting all the way accross the mating surface. Within factory tolerance, but way off from true and parallel. 9" deck height and .040 gasket gives you proper quench and more efficient flame travel during combustion. Zero deck height is when the top of the piston at TDC is flush with the top of the head mating surface.
My advice is to buy a rotating kit. That way you don't have to think about piston skirts clearing the crank throws. You don't have to think about cussing when your high ZUPE main or rod bearings don't fit the crank radius's.
It's also kind of stupid to build a 383 when a 396 cost the same. Out on the 1/4 mile equally built 383 vs 396 is generally about .2 seconds and 2-3 car lengths. At the all Vette drags hot street 383s are usually about 11.70's where the 396s are 11.50's
195cc heads other than the new higher CFM AFR are kind of smallish on 383+ ci motors.
You cam determines your compression ratio. Sub 232 degrees intake max of 10.7 with aluminum heads and SR cam. My present 383 is 11.24 compression and runs better than most peoples 383.
