Help picking 383 engine parts!!!!
Oct 16, 2006 | 01:15 PM
gkull. glad you chimed in.....you always bring a lot of knowledge to the threads I ask about........Thanks very much! How would you put one together, block/crank/rods/pistons for a budget of $1000-$2000 parts? I already have a 010 Block. If you want, kick in a SR reccommendation! Thanks Again!
Oct 16, 2006 | 01:23 PM
gkull, I frgot to say for the 396! Sorry! What would you put on top? Thanks again!
Oct 16, 2006 | 02:04 PM
right from
www.flatlanderracing.com
then on the lower left "Rotating kits" then off on Scat rotating kits
The scat forged 6 inch rod is the same for 3.750 stroke as 3.875. That kit and some machine work is under the $2000 budget for a short block
Crank: 350 Main, 3.875" Stroke, 6.000" Rod Length
Rod: 6.000" 4340 Forged H-Beam Rod w/ARP 7/16" Cap Screw Bolts
Rings: 1/16 x 1/16 x 3/16
Crank # Rod # Piston #
4-350-3875-6000 2-350-6000-2100 144995
# Price $1380
(Type) Bore Size Comp. Ratio Kit
58cc 64cc 70cc
(SRP FLAT) 0.30 12.2 11.4 10.6 1-40900-1
Oct 16, 2006 | 02:28 PM
I would not recommend anykind of a roller cam to somebody on a budget or somebody that doesn't do lots of work on their own car.
Just like I would not jump into a twin turbo EFI setup. Too many things can go wrong and just turn good intentions into a pile of junk within seconds.
My advice is that if you can't say to yourself, "That's racin!" when it blows up. Then you should not be building it in the first place.
I can take on a few thousand dollar melt down and not be bothered too much if it only happens every year or two.
Oct 16, 2006 | 06:20 PM
gkull, Thanks for the suggestion. I'm OK on that, to tell you the truth, I was afraid of you reccomending a $2000 crank!!!!!!!!!!!!! What is your opinion of getting the lighter weight crank, it is 8 pounds lighter & a $260 option? What size chamber do you think I can get, with the bigger displacement, can't I run a little more duration cam? Thanks.
Oct 16, 2006 | 06:32 PM
If your wanting more duration stick with your original plan and use
a solid roller.
Oct 16, 2006 | 08:23 PM
Little Mouse, Thanks, I was planning on the SR.
Oct 16, 2006 | 08:27 PM
