Power steering valve fitting ?
Old Oct 16, 2006 | 01:35 PM
1tuffref's Avatar
1tuffref
Default Power steering valve fitting ?
While changing the power steering hoses on my 77 to repair a leak I ran into a problem. The tapped hole in the valve for the retract hose does not have a cone in the bottom that will match the flare of the hose. When I put the hose on and tighten it all the way the hose just spun freely. I checked the other tapped holes and they all have to cone in the bottom that you would expect and the hoses go on correctly. The bottom of this hole is not exactly flat either it has a slight counter sink to it. Is there a washer or spacer that has the cone in it that should go in this hole first. It would make sense since the valve body is cast to use a hard insert to meet the flare but nobdy seems to know what I am talking about. Anybody have any ideas?
Old Oct 16, 2006 | 02:53 PM
Brad_B's Avatar
Brad_B
This is one of my winter projects on my 77, so
Good luck.
Old Oct 16, 2006 | 03:00 PM
Jim Shea's Avatar
Jim Shea
All of the ports in the valve, assist cylinder, and the pump should have brass 45 degree flare seats in them. I guess that I don't understand how just replacing your hoses, that suddenly the seat in one of the valve ports comes up missing. The hose that was in that port previously should have been leaking a tremendous amount of fluid if the seat was missing.
That being said, I am not sure where you can get replacement seats.
You might try one the Vette suppliers that offers rebuilt control valves (Zip Products, Vette Brakes & Products, Inc, etc). I would contact their tech section. That supplier might be able to sell you a seat out of courtesy. They should be installing new seats in any rebuilt valve that they sell.
Jim
Old Oct 16, 2006 | 03:01 PM
1tuffref's Avatar
1tuffref
Thanks because I think I'm screwed. I talked to one of my tool makers and he believes it is an insert that they pressed in when they machined the casting. It would be too difficult to try to turn the housing on a lathe or even burn the shape into the bottom of the tapped hole. Iv'e got a funny feeling I am going to have to buy a whole new housing or try to get one of the inserts out of the other holes and turn a new one. If it wasn't for this hang up I would have been done with the whole project in about an hour. Since I'm stuck I cleaned the pump and bracket up and geve them a new paint job.
Old Oct 16, 2006 | 03:06 PM
SIXFOOTER's Avatar
SIXFOOTER
did you look at the old hose? Maybe the seat stuck to it. ot maybe Bubba modified the hose to work?
Old Oct 16, 2006 | 03:07 PM
1tuffref's Avatar
1tuffref
Thanks for the verification on my thoughts about the seats. The bushing was frozen on the valve housing and I had to take it off to get the bushing to turn. When I looked at the flare it had compression marks on the very end only and not on the center of the bell. I'm pretty sure these hoses are original so I guess the original assemblers just got lucky. Thanks for the leads on possible replacements too.
Old Oct 16, 2006 | 03:16 PM
1tuffref's Avatar
1tuffref
Yep, as soon as it came out. I think Bubba was working at the Chevy factory the day they put mine together.
Old Oct 16, 2006 | 04:03 PM
saudivette's Avatar
saudivette
Originally Posted by Jim Shea
All of the ports in the valve, assist cylinder, and the pump should have brass 45 degree flare seats in them...
Jim
Do they look like this Jim?
Old Oct 17, 2006 | 12:20 AM
Jim Shea's Avatar
Jim Shea
The inserts in the control valve are similar to the posted picture but they are even more straight forward (no seals). This cutaway of the valve shows the general shape of one of the inserts that is located in one of the ports that feeds the assist cylinder.
http://jimshea.corvettefaq.com/wp-co...lveCutaway.doc
Jim
Old Oct 17, 2006 | 04:53 AM
saudivette's Avatar
saudivette
Wilcox have a Power Steering Control Valve Rebuilding Kit. It doesn't show a picture but I'm sure if you PM'd Wilcox, he'd soon tell you if the seat was part of the kit...
http://willcoxcorvette.com/product_i...oducts_id=1014
Old Oct 17, 2006 | 01:08 PM
1tuffref's Avatar
1tuffref
I'm in touch with a power steering pump manufacturer in CA and they seemed to know exactly what I was talking about. I re-installed the power steering pump and ran the lines that I could last night but now I am stuck with one tire off and the car on jack stands. I cleaned everything up and got a good look into the port and I am definately missing the seat. I just hope to God they don't have to be pressed in or anything else more complicated than a soft punch and a hammer.
Old Nov 7, 2006 | 01:46 PM
1tuffref's Avatar
1tuffref
Talk about a long way home but I think I am finally there. I found out that there were a few different size seats made for this housing depending on who made it. I tried getting one of the seats out but that wasn't going to happen without screwing it up so I measured the hole dimensions and was going to make one when a freind of mine at work told me he had an old distributor valve out of a Chevy truck as old as my vete and I could have it. I had to cut the seats out but their O.D. was .005" bigger then the hole they were supposed to go in. That was way too much for a .250" hole fit so I took them down .003" and pressed the best looking one in with the old flare bushing. So far so good. Tonight I will put it all back together with the new hoses and fire it up to check for leaks. I figure this little trick is pretty low on the Bubba scale but then again I was leaking so much fluid watch it was the seal on my power steering pump and not the hoses at all.
To Power steering valve fitting ?
