Need to replace distributor...
Old Oct 17, 2006 | 08:09 PM
andylmusic76's Avatar
andylmusic76
Default Need to replace distributor...
okay so right now i am installing a heavy Summit cam, edelbrock performer intake and 750cfm carb on my engine. i know my compression is over 9:1. here i didn't really think about it before--i have vacuum timing. i would like to switch over to mechanical for a much better response. what brand would you all recommend as far as quality and price?
Old Oct 17, 2006 | 08:51 PM
BigBlockk's Avatar
BigBlockk
You should never run a street engine without vacuum advance. Set your initial advance at 16 degrees, set the distributer up for 36 degrees mechanical at 2800 RPM and get a vacuum can that will give you about 12 degrees max hooked up to manifold vacuum. 16+20+12=48 BTDC at cruise. That'll work!
BigBlockk
Later.....
Old Oct 17, 2006 | 09:10 PM
big_G's Avatar
big_G
The man speaks the truth!
Old Oct 17, 2006 | 09:21 PM
Bob Onit's Avatar
Bob Onit
Hey Andy L-82/L-48?
What pistons and Heads...If i may ask?
Bob
Old Oct 17, 2006 | 10:22 PM
andylmusic76
Bob,
My car is an L-48, but the engine is a crate engine - 10 years old. It's definitely not the original engine. I am not sure of my pistons and heads.
Old Oct 17, 2006 | 11:04 PM
jackson's Avatar
jackson
What DO you know?
Old Oct 17, 2006 | 11:07 PM
andylmusic76
i know that my mechanic may know, but i don't. i just thought that i would check on here since everyone here has a car like mine.
Old Oct 18, 2006 | 06:47 AM
andylmusic76
bob,
sorry i didn't make that clear...i have a problem with that lol. yes the original engine is long gone, and it is replaced with a crate engine, as far as i know, it's just the basic replacement crate engine that's somewhere like 270 bhp. i already replaced the cam, the duration is 224/234 at .050". i'm sorry i don't know more about it than i do.
also, what would be the reason to stick with vacuum over mechanical timing for a street car?
Old Oct 18, 2006 | 07:24 AM
Gordonm's Avatar
Gordonm
bob,
You still will have mechanical advance on the dist. The vacuum will be dropped out when you run WOT. The vacuum will work at part throttle and cruise conditions. Properly setup the vacuum will increase your mileage while cruising and will not harm anything when running WOT. There is little to no vacuum at heavy or WOT settings so the vacuum can is dropped out of the system. Only on rare occasions, race motors and some motors with very radical cams should the vacuum not be used. For a mild street motor which you have the vaccum will help driveability and fuel economy.
Old Oct 18, 2006 | 10:59 AM
jackson's Avatar
jackson
After MANY similar threads:
My gut tells me root problem is not distributor ... but is too little compression for Summit 224/234 cam.
Intuition says no more than 9:1 SCR ... & probably SUM 1105 (224*/234* .465"/.488").
In lieu of guessing ... Maybe Andy's mechanic can provide head casting numbers, piston & gasket part numbers & machining specs? .... that could facilitate a very useful & reasonable calculation of compression. There are TONS of searchable CF posts about this.
Old Oct 18, 2006 | 03:25 PM
Bob Onit's Avatar
Bob Onit
270 HP was the rating for the L-82.
Does you Corvette have the L-82 badge on the hood?
What does the tag below the shifter say?
Old Oct 18, 2006 | 04:21 PM
andylmusic76
jackson,
I have not driven my car yet since he intalled the new cam. up until now i have been using the stock cam, and what i do know is that it is very mild.
bob,
the vin of my car tells me it was an l-48, but it has the basic 270 hp chevy crate engine in it.
Old Oct 18, 2006 | 05:16 PM
andylmusic76
just out of curiosity, what was the bhp rating of the L-48 if rwhp was 180hp?
Old Oct 18, 2006 | 06:45 PM
Bob Onit's Avatar
Bob Onit
190 HP for 1973
1975 dropped down to whopping 165
I think they went back up to the 190 in '76
I believe the rating was changed from gross to net for one reason or another during the mid 1970's
Old Oct 18, 2006 | 07:01 PM
Kalway's Avatar
Kalway
They changed to net HP in '72. The L-48 didn't have 190hp again until 1980.
To Need to replace distributor...
