Temperature Sender Unit Accuracy
Old Sep 17, 2001 | 04:37 PM
Bill W's Avatar
Bill W
Default Temperature Sender Unit Accuracy
The gauge has been running about 210 throughout the summer and was making me a little nervous. So, I stopped at the local radiator shop this past Saturday. They shot the motor in three or four different places with an IR gun. True temp is 165 degrees. I knew that the replacement sender units read high but I never thought it would be 45 degrees off. Needless to say, it eased my mind. Now all I need to do is put a resistor in the line so the gauge shows the true temp. That project now goes to the bottom of the list. So before you go crazy trying to solve overheating problems, check the true temp with an IR gun. The shop didn't charge anything for doing it either. How often does anything associated with the Vette cost nothing?
Old Sep 17, 2001 | 05:00 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: Temperature Sender Unit Accuracy (Bill W)
Wow thats a Big error!
Where did they measure the temperatures???
Old Sep 17, 2001 | 05:15 PM
Bill W's Avatar
Bill W
Default Re: Temperature Sender Unit Accuracy (427V8)
They measured the temps at the thermostat housing, the sender unit itself, the radiator return neck and a couple spots on the radiator itself. No more than 5 degrees difference between them. I have a 160 degree thermostat currently. I may change that now that I know what the real engine temp is.
Old Sep 17, 2001 | 05:32 PM
Corellian Corvette's Avatar
Corellian Corvette
Actually, I did the same thing this weekend -- finally got fed up after 4 different sending units. Took it to the local radiator shop, they flushed the system and cleaned the radiator (said it looked fine but wanted to do it anyway) -- he took temp readings and thought the unit was about 40 deg off as well...
Old Sep 18, 2001 | 12:33 AM
73 LS-4's Avatar
73 LS-4
I ended up repairing my original sending unit, becouse I couldn't find any other that would work, they were a pretty consistent 40 degrees high though, if someone knows of an accurate sending unit please let us know.
:cheers:
Pat Kunz
Old Sep 18, 2001 | 10:33 PM
virtue4u's Avatar
virtue4u
Default Re: Temperature Sender Unit Accuracy (73 LS-4)
Don't know of an accurate sender, but on a recent post someone calculated how much of a resistor to connect in parallel to the sender to get a better reading.
Old Sep 19, 2001 | 10:36 AM
chrled's Avatar
chrled
I have a similar problem with the temp. I live in south florida, have a 79 with edelbrock performer goodies outside aswell as inside. My engine runs just below 220 when it is a normal day but comes over 220 when extreme´hot outside. The autoshop has flushed it and changed the termostat. Could it be that the sender unit is showing errounous information? What do you belive?
/Chris, Ft Lauderdale
Old Sep 19, 2001 | 11:41 AM
Bill W's Avatar
Bill W
Default Re: Temperature Sender Unit Accuracy (chrled)
Please reread the first post in this thread.
To Temperature Sender Unit Accuracy
