Rear Main Seal Replacement
I think the Rear Main Seal is leaky... is there a way to tell for sure?
If I was to replace the Rear Main Seal... is it really a big job. From what I can tell it is dropping the Tranny, Bellhousing, clutch, oilpan...
Pop out old seal and put in t new one. Is there more to it?
Does anyone have detailed directions on how to do it? With pictures?
I can only get my car on jack stands with just enough room to drop the Tranny(I think).
Thanks for any help.
Here is a pic of what it looks like, and when it is installed the seal will be in this position.
http://www.napaonline.com/masterpage...+Main+Seal+Set
So with that said, am I looking at a fair easy job?
Get the stearing linkage out of the way... drop the oil pan... pry old seal out top and bottom... slide new seal in top and bottom?
but that's just me.
Steering linkage should drop down enough just by unbolting the ideler arm from the frame. On a SB, the oil pump & pick up must be removed to gain access to the main cap. Not sure about the oil pump part on your 427. Your new seal should come with a shoe horn (plastic tab) that aids in sliding the new seal in without damage. Use it!!!
Eddie
I will be sure to inspect them both while I'm in there doing the seal though.
No big deal if you want to swap in a new one at that point.
If you're adventurous and desire to replace the main bearings that too is pretty simple to do WITHOUT removing the crank.
You remove/change them one cap at a time and roll the bearing in/out/around the journal.
On the other hand, if you only have a leak I wouldn't spend much time replacing the oil pump and bearings if your only reason is "while you're in there".
You'll soon find out that the hardest part of replacing the rear main is getting the car up high enough to perform the work. After that, drop the idler arm (as pointed out above), remove the pan, oil pump, and rear main cap then carefully replace the seal as described in the directions that come with the seal.
If you're smart you'll replace the oil pan gasket with a one-piece gasket (search on that topic and you'll find part number/mfgr for that item).
When you buy your rear seal ask the counter person about the optional "offset" seal.
How high do I need to get the Car?
And I plan on replacing the Oil Pan Gasket with a new one piece... should the Oil Pan Gasket go on Dry or should I be using some kind of Sealer?
Eddie
Additionally I am getting new valve covers... obviosly I will be replacing the Gaskets... Should I go with rubber or Cork??
