Side yoke seal replacement.
Old Sep 17, 2001 | 10:43 PM
bn7035's Avatar
bn7035
Default Side yoke seal replacement.
I noticed that a seal at the side yoke is leaking. Do you have to pull the differential and if so how much of a problem is it (not pulling the differential but tearing into it).. My manual says to take it to a dealer. Its on a 81. I noticed that in the AIM manual the side yoke has a clip ring on the end of it and I guess it would be to easy to slip out like a driveshaft. I do not care to buy a rebuilt one because it has an easy 50K miles on it.
Old Sep 17, 2001 | 11:18 PM
sb69coupe's Avatar
sb69coupe
Default Re: Side yoke seal replacement. (bn7035)
You have to remove the diff and side yoke to replace the seal. It's not a hard job to remove the yoke and replace the seal, the hardest part is dropping the differential. It's supposed to be easier on your 81 than the early cars though.
Shannon
