Help decipher numbers please
Oct 22, 2006 | 06:49 AM
St. Jude Donor '14
Found these numbers on my engine ('78).Any idea of what engine this is?Car's VIN says it's an L48.
34624912.
Thanks.
Oct 22, 2006 | 09:01 AM
Where were the numbers, cast in the block or stamped on the VIN pad?
Oct 22, 2006 | 09:11 AM
St. Jude Donor '14
Quote:
On block,under carb towards the rear.
Oct 22, 2006 | 09:26 AM
Quote:
That's not the block, it's the intake manifold. The numbers you found (346249) are the casting number of the manifold. It was used on 75-78 Corvettes.
Oct 22, 2006 | 09:27 AM
Not sure what the extra 12 means. Is it all one number or is the 12 seperated?
Oct 22, 2006 | 10:46 AM
Quote:
I agree, that's what it shows in "Corvette by the numbers" for 75-78 intake manifold.
Oct 22, 2006 | 12:37 PM
St. Jude Donor '14
Quote:
the 12 is under the other numbers.I've looked for the engine number and can't find it.
Oct 22, 2006 | 02:06 PM
theI've looked for the engine number and can't find it.
There are 2 more places you need to look
Ome is on the drivers side near the firewall where the transmission/bell housing mates to the block
This will be a raised cast number
The other is a stamped number which is located on the front drivers side on a pad just below the front of the cylinder head
It may be coverd over with paint or normal grease, dirt ect: so you mat need to wire brush it to get a good reading
Heres a pic of the stamped number
You can also part of the water pump and the fuel line to the carb so it may help with finding the stamped number
Oct 22, 2006 | 02:19 PM
St. Jude Donor '14
Thanks,I'll go check it out
