Edelbrock Carb Advice needed
Chevrolet 262-400 Small-Block V8
PERFORMER - '86 & EARLIER (idle-5500 rpm)
Designed for street 1955-86 262-400 c.i.d. small-block Chevys. #2101 is stock replacement/street legal part for 302, 327 and 350 V8s with OEM 4-bbl. or Edelbrock #1400 carb; 1966-72 (1973 non-California) cars, 1966-83 trucks and Suburbans; except stock equipped EGR. #3701 is stock replacement/street legal part for 305, 350 and 400 V8s with OEM 4-bbl. or Edelbrock #1400 carb.; 1972-86 and GM corporate engines with 350 V8s; 1981-86. Performers accept late-model choke, waterneck, air-conditioning, alternator and H.E.I. Has provisions to add oil fill tube. Not for 1987 and later cast iron or Chevy Bowtie heads. Will fit 1987 and later stock aluminum heads. Available with standard finish or polished.
Performer (non-EGR) #2101
Polished Performer #2101 (non-EGR) #21011
Performer (EGR) #3701
Carburetor Recommendations: OEM 4-bbl., use choke rod #9171, bracket #8031 or #8036 for 1972-78 Edelbrock Thunder Series AVS or Performer Series carb, 500-650 cfm (see Carbs & Accessories), use bracket #8031 or #8036 for 1972-78
Thats why I replied with a no
Since the engine isnt stock do you guys think the 600 CFM will be enough?
I believe theres a 1407 as well
Im sure the Edelbrock will serve you fine if you want a dependable carb that has good performance
As far as the 600 vs 700 cfm, I dont know the answer..sorry
2 months old, $175 and your good to go. #1406 w/elec choke, see pics.
[/IMG]
http://i96.photobucket.com/albums/l1...lowered100.jpg
#EDL-8030
but diddnt want to say it as 72 Ttop diddnt want to hear it4 rebuilt QJ's and no positive outcome?
I'm guessing they were Comercially rebuilt units which are essentialy garbage
Or... one rebuilder that has now idea how to rebuild a Qjet....
And Ganey, when you say Holley makes a DIRECT replacement, what does that mean, bolt on and go or redo linkage and vacuum hoses and?
and Sensei...oh, you are sooooo right...I know it is not the carb and I have not had 4 Qjets rebuilt, just one..twice. The problem is that I sent the Qjet to be built by the most reliable person on this forum and when it came back my mechanic could not make it work...so I was (once again) stuck in the middle and screwed...
so my belief and someone PLEASE tell me if I'm wrong, is that I should be able to buy a carb (whatever model) that functions basically the same as the Qjet and has good performance, good gas mileage, starts easy, fits correctly, and doesn't need "tinkering" with all the time.
The local corvette shop, who I have basically lost faith in, could not get my Qjet rebuilt, so I sent it away to a pro. When it came back, they could still not make it run acceptably... in the meantime, they had an Edelbrock something, rebuilt, and it ran like crap, and then they put on a new Holley (don't know the model, and it developed a host of problems, including stuck accel pump and gas leak, and it was NEW (they said)...? Having a car that was leaking gas and some needed warrantly work (oil leaks on new engine), I had them put on the rebuilt Qjet when it came back from the expert rebuilder. It wouldn't run and when I went to pick up the car, I found that they had put on an old AFB they had in stock and I was so grateful to get my car away from them and it ran great, that I drove away with a carb I didn't want...
so, now my quest, believing that my qjet cannot be rebuilt correctly, and not having a mechanic I trust, is to just buy a new carb that meets my needs. It just appeared from my reading that the Edelbrock would be the fit the best, need the least amount of tinkering and give me basically a good sound all around carb without a lot of rework.
Go with Edelbrock 1406..I just hope it runs properly out of the box because you have stated your engine is not stock and you needed a mechanic to install it..
As far as Edelbrock 1400 series VS the Qjet, Ill leave that up to your own research ...Basicaly one is a square bore and the other is a spread bore variable CFM
One has been tried and true for 25 years and one is fairly new to the market.
I will not get into an arguement over carbs..Ill leave it to you to make the choice
I also suggsest you find a new mechanic.
Unless a QJet has physical damage it can be revived/rebuilt providing you have the right person doing the job
It is also possible that perhaps the carb is not your main problem
Maybe ignition is the main issue..who knows as you never explained the symptoms in detail
Good luck
Bob
The Edelbrock square bore is the AFB. Now that you have the AFB installed, the Edelbrock square bore is a direct replacement. You might want to run it awhile & decide.
PS Edelbrock also has new Q-Js.
