Battery light ON
Old Oct 23, 2006 | 06:33 AM
pdege's Avatar
pdege
Default Battery light ON
The dash battery light is glowing a nice bright red with the ignition switch OFF??? Turning the ignition on turns the battery light off.
Prior to this the light switch blew a fuse and I replaced fuse and switch. Also replaced courtesy light timer (through the glove box). Could a wire have come off? but where do I look?
Very, very confusing. Need a charging guru to help
Old Oct 23, 2006 | 07:36 AM
...Roger...'s Avatar
...Roger...
2 things can turn on this light-generator or choke heater relay-check your "choke heater fuse"------if that doesnt work unplug 2 wire connector on alt. and if light goes out have the alt. checked.
Old Oct 23, 2006 | 10:49 AM
SIXFOOTER's Avatar
SIXFOOTER
Yep
Old Oct 23, 2006 | 11:32 AM
pdege's Avatar
pdege
Sure enough the fuse was blown.
Light still ON. Pulling the alt connector didn't do anything.
Is this telling me the relay is cooked or do I look somewhere else?
(Where do I get one? Napa and Autozone don't list them nor do Ecklers, CorvetteAmerica, CorvetteCentral)
To Battery light ON
