I have the stock iron manifold #349249GM on my 75. Or I have an aluminum #14057053GMCFM that I've had
laying around my garage for a couple of years because someone told me it came off a Corvette, it looks like it
has all the same connections. Is there anything special about this aluminum one? It has a metal plate (splash
shield) underneath, I think it's to keep the oil from touching and heating the bottom of the manifold. Should I
swap them??
The only info I could find on 14057053 was that it was a manifold used on 350/305's between 78-85 for passenger cars, Camaro's and trucks. The aluminum intake on my L82 is 14007378GMCM. I believe GKULL maintains that the L82 manifold is = Edelbrock Performer. I don't think the aluminum manifold you have is the L82 manifold, so I would say no. I think the only thing you would accomplish is drop some weight and possibly reduce performance.
Vizard had dyno'd stock manifolds vs. aftermarket. It seemed that below 3000rpm, the stockers made equal or more HP than the aftermarket. Something else to consider.
79MakoL82 years ago i bought the Edel.performer for quadrajet to boost performance I hoped! It looked nearly Identical on all internal dimensions to the 79 L-82. But I put it on anyway and didn't notice a bit of difference. It's a common practice to let GM engineers or others do the research and then copy and market it with subtle changes to not infringe on patent rights. It's the American way. :chevy
Just one of the reasons why I would not recommed any of the low rpm dual planes. It all in marketing.
gkull: See, I do listen. :D My thinking is that if you're going to swap from a non L82 style manifold to a non L82 manifold, you mine as well go for an RPM or something similar. I was just thinking it probably wouldn't be worth the effort in this case just to shed a few pounds, although I admittedly don't know the exact engines that bore his particular aluminum manifold, it wasn't the Corvette engines. :smash:
