SBC Intake Bolts
Old Sep 18, 2001 | 02:46 PM
e3pres's Avatar
e3pres
St. Jude Donor '08-'09
Default SBC Intake Bolts
I am about to install my aluminum intake on my new motor. I bought a set of Mr. Gasket (I know... I know...) intake bolts. I don't feel confident that they are long enough to accomodate my A/C bracket. I can only get a couple of threads into the block with that particular bolt. What is everyone else using? (I don't want to reuse the originals.) Could I just use standard bolts, if so what are the specs on them?
TIA,
:flag
Old Sep 18, 2001 | 02:59 PM
Gator81's Avatar
Gator81
Default Re: SBC Intake Bolts (e3pres)
If you've still got the originals, or if you know the length you need, just hop on down to the local hardware store for some grade 8 (or at least grade 5) replacements. Home Depot, Lowe's, Tru-Value, PepBoys, should all have the right bolts. I wouldn't use anything less than grade 5 (3 lines on the head).
Old Sep 18, 2001 | 04:55 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
be careful because if the bolt is too long it will hit a pushrod and bend it
To SBC Intake Bolts
