82 Crossfire Idle fun fun
The car is Idling at 800-850 RPm in park and around 600 in gear. The car Idles rough at the lower RPMs and shakes. Here is the funky thing with the door open the lights in the interior of the car are flashing/strobing. What the heck is going on?
I have a stable idle aswell (finally) but mine also is rough at low RPM. Only thing i can think of...after replacing every single sensor is the throttle shafts. I have quit a bit of play...going to try fixing that next...
Jim
- Headlight system
- Cruise control
- EGR system
- A.I.R. diverter valves
- Heat/cooling controls
- Evap purge canister (sol and line)
Need to check the plenum gasket again. The only things that were not leaking were the MAP and Brake Booster (fixed the line leak).
It idles a lot better with all the leaking stuff capped off for now (till I chase down and fix each one).
