Block Sanding
Old Oct 23, 2006 | 08:05 PM
1980ZZ4's Avatar
1980ZZ4
Default Block Sanding
What do you guys recommend for block sanding? Anyone use long flex boards? Need recommendations.
Thanks,
Brad
Old Oct 23, 2006 | 08:09 PM
gmg1977's Avatar
gmg1977
Im using the foam sand paper from 3m and a block fron autozone. May not be the most professional but it works
Old Oct 23, 2006 | 08:14 PM
bondoboy's Avatar
bondoboy
Always use the longest board that is practical for the area you're sanding. The hood, deck, and tops are about the only place a rigid board can be used. Everything else is curved. Some companies make long flexible foam blocks, such as durablock. Get sandpaper on a file roll and you can tear off as much as you need for any size block that you're using.
Old Oct 23, 2006 | 11:59 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I like using the firm rubber pads that you wrap your sand paper around. They Are sold by most auto body supply stores.
Old Oct 24, 2006 | 12:07 AM
jayr's Avatar
jayr
Go to AutoBody101.com. Its a wonderful site for any questions about
bodywork, buffing and painting.
To Block Sanding
