Roller TIP Rockers +noise
Old Oct 24, 2006 | 03:34 AM
Bob Onit's Avatar
Bob Onit
Default Roller TIP Rockers +noise
Hey all
I have a set of Crane Magnum Roller TIP rockers and I can hear a faint ticking sound
Are Roller tip Rockers supposed to make any noise?
Here is a very similair example if not identical
Bob
Old Oct 24, 2006 | 08:13 AM
73BLWN's Avatar
73BLWN
I had those installed on my sbc and yep they make a constant ticking noise. It drove me crazy. I was constantly readjusting the valves hoping the ticking would go away. The ticking never went away. I went to Crane aluminum full roller rockers and everything is all better now. Good luck.
Old Oct 24, 2006 | 08:31 AM
bashcraft's Avatar
bashcraft
Is your cam solid or hydraulic? If hydraulic, there shouldn't be any noise, unless the lifter isn't taking up all the lash. Are they anti-pump up lifters?
Old Oct 24, 2006 | 10:27 AM
stingr69's Avatar
stingr69
They are not supposed to make noise. Mine are quiet on the hydraulic cammed engines.
How do you know it is a rocker arm making the noise? Have you isolated the particular cylinder yet? Could be header leak, general valvetrain wear, seat issues, piston/head interfearance from ingesting a piece of crap, rocker arm nut backing off, etc.
-Mark.
Old Oct 24, 2006 | 11:00 AM
jack 69's Avatar
jack 69
Default tick
Originally Posted by Bob Onit
Hey all
Bob
i have the same noise on all my rockers... same rockers (BB) 20/50 oil helps but when it gets 195 the tick is back
Old Oct 24, 2006 | 11:01 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
A bit off from the question, but I don't think there is any advantage to roller-tip rockers. On at least some of the LSx engines, GM has been using rockers with a roller trunion and a standard tip. An archives search should turn up some very interesting past discussions.
Old Oct 24, 2006 | 05:54 PM
Bob Onit's Avatar
Bob Onit
It was an exhaust leak .... either cylinder 5 or 7
I need to buy decent gaskets, I think I will go for the header bolts with the locking Allen head
Bob
Old Oct 24, 2006 | 06:38 PM
Gordonm's Avatar
Gordonm
Bob
I had that happen on my first time to the drag strip a long time ago. I thought something was really wrong with the motor. Got home and felt pretty stupid for not checking that at the strip. I use Permatex High Temp gasket sealant on the gaskets and the yhave never leaked since. I have even had the gaskets off a few times and still no leaks.
Old Oct 24, 2006 | 10:27 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Bob
Good Choice Bob! http://www.go-breslin.com/text.html
Old Oct 24, 2006 | 10:35 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
make sure you are not bottoming out in the hole.....
Old Oct 24, 2006 | 10:38 PM
63mako's Avatar
63mako
I kind of enjoy that!
Old Oct 24, 2006 | 10:45 PM
bobs77vet's Avatar
bobs77vet
the water is cold, and deep too......
To Roller TIP Rockers +noise
