Power Windowss
Old Oct 24, 2006 | 12:48 PM
Darthvetter05's Avatar
Darthvetter05
Default Power Windowss
Me again! Got the car running real well finally! Still need to tweak the Q-jet a bit more to get it to idle nice and to get the choke working as it should. Thank you all for your advice and support.
issue I am having now is the power windows will not work. I disassembled the switches because I know they are like fly traps for gunk. And indeed, they were nasty, so I cleaned them and reinstalled. Problem is now I have no power coming to the plugs for the switches. On the fuse block, I do not see a specific place for a fuse for the windows. Is it shared by another system in the car? The only fuse missing is for the radio. All the others are there and are not blown.
Sorry, for those of you who haven't followed my plight, this is a 77 model.
Old Oct 24, 2006 | 12:54 PM
SIXFOOTER's Avatar
SIXFOOTER
The windows are powered from a circuit breaker on the fuse panel, if I remember correctly, upper right side of the fuse panel, 35 amps.
Old Oct 24, 2006 | 01:00 PM
Darthvetter05
Perfect. Thank you very much.
To Power Windowss
