Emergency flashers not working
Old Oct 23, 2006 | 06:37 PM
asianlimodriver's Avatar
asianlimodriver
Default Emergency flashers not working
Any ideas of what could be wrong? My turn signals and brake lights function fine. When I push in the emergency flasher ****, the dash signals flash on and off, but nothing happens with my front and rear lights. Could it be a bad emergency flasher switch? If so, are they hard to replace?
Old Oct 24, 2006 | 10:30 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
My round flasher fuse thingy is located behind the passenger vent just in front of the door below the dash. It's not hard to replace, if I remember correctly, the door sill has to come off then its pretty much self expainitory how to take the plastic vent cover off.
Old Oct 24, 2006 | 10:58 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
That one is only for the turn signals. The flasher for the emergency signals is on the fuse box.
Old Oct 24, 2006 | 11:07 AM
genuine1980's Avatar
genuine1980
Correct me if I am wrong... if his dash signals flash on and off when he puts the emergency flashers on... then it isn't the emergency flasher.
Old Oct 24, 2006 | 12:46 PM
spedaleden's Avatar
spedaleden
I would take a multimeter and check for voltage or ground in the harness going to the fuse block from the steering column
Old Oct 24, 2006 | 01:11 PM
7T1vette's Avatar
7T1vette
It's not the flasher units (since the turn signals work and the dash indicators flash with the emergency switch). I think the only place left to consider is in the contacts in the steering column. That's where the lines to the dash indicators and to the outside bulbs get split. The signal is being produced properly and it is going to the dash indicators, but not the outer bulbs. Must be in the column. Good luck.
To Emergency flashers not working
