rebuild or rebuilt
Old Oct 24, 2006 | 06:28 PM
pushin_400's Avatar
pushin_400
Default rebuild or rebuilt
i sent the frame off my 77 off for full restoration. now i have my engine to work with for 2 months.
what is the smartest thing to do rebuild the exsisting engine which i believe runs or buy a rebuilt one.
what would cost less.
and if i were to rebuild, i lookin from scartch, where would i start?
thanks everyone
p.s. ne pics of pple who have done the same, i would like to see.
steve
Old Oct 24, 2006 | 07:21 PM
pushin_400's Avatar
pushin_400
does the blocks come assmebled
Old Oct 24, 2006 | 07:43 PM
Little Mouse's Avatar
Little Mouse
GM performance parts crate engines. 290HP, part# 12499529
$1625.80. 330HP, part# 124486041, $2389.95
sdpc2000.com
Old Oct 24, 2006 | 11:29 PM
pushin_400's Avatar
pushin_400
so u think it wise to just drop a new block in, instead of rebuilding the exsisting one?
Old Oct 25, 2006 | 12:01 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Whatever you decide, keep the original engine. You never know, these C3's could take off in value someday and that is when originality becomes important.
Old Oct 25, 2006 | 12:52 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
I personally, would do a crate motor if your not doing an NCRS car but trying to keep it as original as possible. You never know, you could send your original motor out to have it rebuilt and express to them not to take the numbers off the block and than get it back to find out they did just that. Ask me how I know.
Old Oct 25, 2006 | 08:26 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I'm old school, but I would rebuild my original engine.
Old Oct 25, 2006 | 08:55 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I'd get a nice performance crate engine and keep the original block for eventual resale. You can get nice crate engines for a good price, probably much cheaper than it would cost you to have your engine rebuilt..
Old Oct 25, 2006 | 08:57 AM
halfmoontrail's Avatar
halfmoontrail
In my experience with many GM V8s: Rarely do they need a "rebuild". Also, my experience and opinion is that the first build of an engine is likely to be the best and longest lasting.
My advice would be to determine if there is anything wrong with your engine (various compression tests, measurements, and oil/component inspection), and only fix what's broken.
Beyond that, I prefer a medium mileage used (not rebuilt) engine from a salvage operation. Usually warranteed for some period of time. Just imagine all of the suitable Chevy small blocks which would slip right in.
If you want to spend money, I'd suggest a GM crate motor instead of a rebuilt engine, or a new engine built up by someone other than GM
Steve
Old Oct 25, 2006 | 09:44 AM
SIXFOOTER's Avatar
SIXFOOTER
I would rebuild, put in good parts and a little hot rod machining to ballance it, just don't let them take off the numbers. Good cam, heads and manifold, carb should be good. All that can be done without getting too psychotic, original motor still there, drive it another 30 years
Old Oct 25, 2006 | 10:18 AM
vettfixr's Avatar
vettfixr
First decide what you are going to do with the car.
If you are going to race it, even ocassionally, or use it for long trips, or use it regularly for daily driver duties I would go with the crate engine and keep the original on the side.
If the car is going to be used for shows or the ocassional Sunday drive or will be driven less than 2000 miles a year I would do a rebuilt (really, a freshining up) of the original motor. My car fell into this category. I pulled the original engine and after measuring everything decided that all it needed was a freshining up. I'm pretty sure it cost me less than $1K. I bought a rebuild kit from Summit which included new main and rod bearings and new gaskets and oil pump and I bought a set of World SR Torquer heads since the originals were trash. I also added a performance cam, although not a very big one, and a new intake and carb. The engine runs very well and uses no oil and has reasonable performance.
One other thing you should remember. You'll never be able to get back the dollars that you put in the car. If you plan to keep it for a while your expenditures, spread out over time, are less of a drain than plowing a lot of money into the car and then selling it a short time later. Just something to think about.
Good luck in whatever you choose.
Old Oct 25, 2006 | 02:04 PM
stingr69's Avatar
stingr69
In addition to what was already posted I would ask yourself if you have a good trustworthy machine shop available to you. We have few around here.
If you have the shop, tools, and time, you should overhaul it yourself. If you have to ask the question, you probably need a crate engine. They save time and bypass the need for a local shop. The only drawback is having to store the original engine if you have one.
-Mark.
To rebuild or rebuilt
