so im going with the suspention first..
Old Oct 24, 2006 | 08:31 PM
Shirley1978's Avatar
Shirley1978
Default so im going with the suspention first..
i decided its better to rather start with the suspention and have a good foundation rather than start rebuilding the engine (its cheaper too ) ok so im going with the performance plus kit from vbp.. which alot of you guys have. and i was wondering, is this something me and my cousin can handle at home in a garage or should i just send it out and get it done instead??
we like to wrench but i cant say we're gear heads in that perspective
Old Oct 24, 2006 | 08:43 PM
rcread's Avatar
rcread
For the most part, it's something you can probably do yourself. You will need to send the car out to have it aligned when you are done.
Old Oct 24, 2006 | 09:21 PM
gyopp's Avatar
gyopp
Search for previous posts on the subject, think things through, and be careful. The springs (front and rear) will have tension on them that could hurt someone if they are not removed properly.
Old Oct 24, 2006 | 09:28 PM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
Doing a suspension rebuild is the best investement you will ever make to the vette. Did mine last winter, started with the rear (hardest depending on trailling arm bolts). I'm just a hobby mechanic and completed everything myself. You will need a couple of special tools but everything is available or just send the parts out and have them done.
Old Oct 25, 2006 | 10:55 AM
VBP's Avatar
VBP
St. Jude Donor '07,'13
Default Forum Discount
When ordering your Performance Plus Kit, don't forget to mention your Forum membership, it get's you 10% off. On the Performance Plus Kit that's a big savings
Pattie
VBP
Old Oct 25, 2006 | 01:29 PM
682XLR8's Avatar
682XLR8
Johnny-Took a look at the kit you mentioned, I think it's something that you and your cousin can do. Take the car to Kraus Racing in Castro Valley for an alignment afterwards.
If you need any tools, let me know, got all kinds of'em
Old Oct 25, 2006 | 02:38 PM
JPhil's Avatar
JPhil
"And While You're At It..." that's a good time to rebuild/replace those leaky brake calipers and squishy brake lines!
And yes, unless you're really mechanically inept, you can do it at home.
Old Oct 25, 2006 | 09:59 PM
Shirley1978
yeah if anything ill probobly end up doing it at your house cuz now that i think about i.. i have tools.. but they're all over the place!.. i wont get it for a while.. maybe a month.. but ill pm you later when i have the green light
Old Oct 25, 2006 | 10:00 PM
Shirley1978
oh yeah.. got that taken care of.. got a new master cylinder and new starter.. along with some ajustments to the carb man that thing feels soooo much better. im makes me go like this
To so im going with the suspention first..
