rear squeak
Oct 25, 2006 | 12:17 PM
rear squeak
i have a 79 vette that now has a squeaking noise from the drivers side rear tire. what would cause this.brake calipers are a year old
Oct 25, 2006 | 12:21 PM
Quote:
Parking brake adjustment maybe? I am only guessing, but when I had a squeak back there I made an adjustment to the parking brake and it went away.
Oct 25, 2006 | 12:22 PM
ill check that tonight. thanks
Oct 25, 2006 | 12:34 PM
Oct 25, 2006 | 12:42 PM
ill check that at the same time. and will probably just change it. thank you. save the wave
Oct 25, 2006 | 12:59 PM
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Does it go away when you apply the brakes?
Oct 25, 2006 | 04:06 PM
It may sound silly but with the brake design that these cars have it might just be the brake pad moving back and forth. the placement of the pin allows some movement between the pad and the sides of the caliper. I bought a kit from Ecklers called the ultimate answer. Its just some hard plastic straws that slide into that area which prevents the movement. Anyways it worked for me.
Good luck
Oct 25, 2006 | 07:29 PM
i think it did. but it never did it before. the squeak that is
