Capt'n Lee's stripper experts needed....
Old Oct 25, 2006 | 10:09 PM
75coupered's Avatar
75coupered
Default Capt'n Lee's stripper experts needed....
Hello all;
In researching various paint stripping methods and my case of 3 coats of paint I decided to use Capt'n Lee's stripper on my 75, took me about 15 hours to get the whole car done, reapplying the stripper 3-4 times to get all of the old paint and primer coats off.
I washed each pannel with water and then wiped with lacquer thinner. I found two small repairs that had been fixed with short strand glass filler and some type of putty filler, like bondo.
Question regarding the filler as well as body seams, all of my seams are in great shape and show no cracks, has the Capt'n Lee's been absorbed into the seams and filler? Do I have to grind these out and replace or will I be fine? I'm affraid of the Capt'n Lee's comming back to haunt me later.
If you used Capt'n Lee's for your car, please let me know how you addressed these concerns and what your results have been.
Bill
Old Oct 25, 2006 | 11:31 PM
1980ZZ4's Avatar
1980ZZ4
Bill,
I used the same stripper. I've heard that if you've exposed any bondo type filler that is not fiberglass that you should grind it out and replace it. As of the seams, I replaced both my bumpers with the tru flex type and therefore don't have that situation. I'm not sure what else to tell you.
Good luck,
Brad
Old Oct 26, 2006 | 12:41 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I used this stripper on a '75 and never had a problem. However, I did redo the seams. I would suggest doing the seams as that way you'll be safe and the job we'll be done right. You could also call the Capt and see what they say.
Old Oct 26, 2006 | 08:27 AM
75coupered's Avatar
75coupered
Thanks Brad and Jud.
Luckily the bondo areas are small, so not much grinding, it's the body seams that run the length of the car that I'm worried about, mine look great and are not soft to the touch after the stripper like the bondo stuff was.
Jud, what did you use to replace the body seams?
Also on filler is there a preference polyester based?
Lastly did you guys let your car sit for a while and evap all of the old stripper before sealing or did you jump right in to the sealing, primer etc after stripping? I'm in south Florida, so I plan to let the body sit in the sun a couple of days before I put the sealer on.
TIA
Old Oct 26, 2006 | 08:45 AM
Jud Chapin's Avatar
Jud Chapin
TIA
I used "Duraglass" on the seams as a knowledgable friend that was helping recommended it. This product sets up very hard and therefore is more work when block sanding the area for straightness. However, you won't have to worry about seam shrinkage again. I'm sure there are products that are easier to work with, though. As for the bondo area, I would definitely strip that section clean of bondo and redo it with a premium product. I stripped and painted a '75 vert several years ago with the help of a friend who really knew his stuff and I'll tell you 1 thing, it's a hell of a lot of work to do the job right.
Regarding letting the car sit, I was working full time so, yes the car sat for quite a while. Of course after the car was stripped, we spent quite of bit of time block sanding the entire vehicle which, as you know, really makes the difference. I remember using tons of water after the stripping as this is supposed to neutralize the stripper. Good luck!
Old Oct 26, 2006 | 11:07 AM
vettfixr's Avatar
vettfixr
I'll tell you what happened to me.
I used Capt'n Lee's and stripped my car to the fiberglass. For a final rinse I used water with dishwashing liquid and went over the whole car with 400 grit sandpaper and scotchbrite pads, flushing all the time with water. I've never had any problem with residual stripper using this method.
My problem occurred with addressing the deams on the fenders. When I looked at them they appeared to have superficial cracking which I thought to be cosmetic. I smoothed them out with a bodyfiller and them primed and painted the car. It looked great for about a year but then the cracks started coming back. I had to go through the entire stripping process again. This time I ground out the seam filler and fiberglassed all the seams which effectively makes the fenders all one piece. This did the trick. Its been probably 12 to 15 years since I did this and no cracks have returned.
The problem with seams is you can't see what's happening behind the filler on the bonding strip. If that area is weak the panels will expand and contract and eventually crack. It might take a little time now but the savings in the long run (not having to do it all over again) are worth the effort to bond the seams together now.
Good luck in whatever you decide.
Old Oct 26, 2006 | 12:11 PM
C3 4ME's Avatar
C3 4ME
I used Captn Lees on mine last winter and have had no problems. The bonding seams were reworked by the painter, mine were all sunken in. The car sat a month before going to the painter, but as mentioned above, each panel was washed with water thouroughly and then wiped down with laquer thinner. This was done before the car sat for a month. 6 months later, I've had no issues whatsoever.
Old Oct 26, 2006 | 03:42 PM
75coupered's Avatar
75coupered
Thanks Vettfixr, Regarding your seam did they show any cracking in the paint prior to the first stripping, or was that after you took the paint off?
In terms of glassing them, did you go resin and fiber or just use the short hair filler?
As to the washing process how much time do you have to do this, should it be done after every panel or once the car is done? I started my stripping 3 days ago and finished yesterday, I washed down each panel done with water and a scotchbrite pad, dried and then wiped down again with lacquer thinner afterwards.
Should I wash down the whole car now or can I wait until after initial sanding?
Thanks for all the input this helps out.
Old Oct 26, 2006 | 04:03 PM
75coupered's Avatar
75coupered
Default some pics 56K warning
Here's some pics of the progress thusfar:
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Oct 26, 2006 | 04:33 PM
iNdigo's Avatar
iNdigo
That's looking real good there... it doesn't appear that you have a whole ton of body filler on there, but in case this helps... in my situation there was much more filler, even filler of various colors. there was some pink stuff, some flesh colored stuff (the good kind), some blue stuff and some green stuff. (Tijuana body shops are not known for their choice of premium materials) I found that if the stripper was left for too long, it would definitely absorb into the filler, to the point where after washing, you could pretty much dig it out with your fingernail.
Now I don't know how much of that was attributed to poor mixing of filler and hardener (obviously the last person who worked on mine wasn't very consistent), but depending on how long you left stripper on the surface, you may want to at least go over the surface of exposed filler with some 400 grit to give it a clean finish.
You certainly want to surface to be as smooth as possible in terms of contour... but when you go over it with primer sealer and primer surfacer, you'll be able to fine tune the contours to whatever level of perfection you decide to invest your time into with the block...
Just consider yourself lucky you didn't find what I did when I stripped the paint off... all my fenders were trashed, cracks all along the ridges front and back at the main sidepanel / top seams, spiderwebbing on the deck, fenders installed with rivets (which weren't removed, then bondo-ed over!), "shaved" door locks and side marker recesses, etc. etc. Took like 1200 hours of work to get it ready for paint... I kid you not.
Old Oct 26, 2006 | 06:14 PM
75coupered's Avatar
75coupered
Default wow
1200 hours
I'm real happy, this one is in nearly no-hit condition, the front drivers bumper was tapped twice, once before the last cheap re-paint and once after, the good thing is that it was fairly light, the original bumper is intact as is the egg crate impact plastic and you can see where the impact was, but no straightening of the bumper is needed and a new urethane bumper cover are all that's getting replaced, even the bumper cover mounting clips were not deformed. Just a little glass in the front drivers fender and both front wheel arch tops about 2-3 in each, the rest of the body is free of repair.
This one's originally from southern CA and the frame shows it, no rust other than surface dust, the windshield pillars and the birdcage are the same, a smidggen of rust dust on the leading edges of the metal but all else was OE paint and nice, the worst were the no. 2 body mount bushings behind the door kick panels, there was some scale here, but very little some loosening and de-rusting and that's it, I treated all the frame and mentioned areas with zinc posphate, topcoated only where needed and have moved on to the body which seems to be in very good condition as well.
back to sanding
Old Oct 27, 2006 | 07:45 AM
vettfixr's Avatar
vettfixr
I washed each panel as I completed it. I didn't want the chemicals to stay on the bare fiberglass and to be honest it makes the process a little less messier. Some of the seams on my car showed cracking through the original paint jobs and there were some shrunken areas as well. To make the repairs I ground out the seams in a V pattern which ended up with an area about 1 1/2 inches wide and then laid in fiberglass and resin in 3 layers. Once it was cured I sanded everything flush and repaired any low spots with more resin and fiberglass. I was very unlucky with filler on the previous paint job. It always seems to shrink and show through the topcoat. Maybe that's because of the lacquer paint but in any case I didn't trust it. After all the fiberglass work was done I used body filler to fill in the pinholes in the fiberglass and this worked well. There probably isn't 1 full ounce of filler on my entire car and so far there's been no reoccurring problems with the topcoats. After you shoot the car with primer check all the fiberglass work and fill any pinholes with a light filler or glaze. I used Nitrostan but you might want to use something a little more modern. One thing that's most important, your primer job should look as good as your final topcoats because anything thats wrong in the primer will be wrong in the topcoats. I went so far as to do a final sand on the primer with 1000 grit sandpaper just as though I was color sanding it. Here are the results showing the type of relection you can get after the topcoat is color sanded and buffed:
Old Oct 27, 2006 | 11:37 AM
75coupered's Avatar
75coupered
Thanks vettfixr, that finish looks amazing!
I take it you stayed with lacquer paint? When you mentioned topcoat, did you clear lacquer over your paint a few times?
For now I'm leaning towards staying with lacquer if I shoot the car and for originality purposes, this is really just a garaged weekender car so I'm not as concerned with durability as with finish quality.
Thanks to all I'll keep you posted as this progresses
Old Oct 27, 2006 | 12:25 PM
vettfixr's Avatar
vettfixr
Yes, I stayed with lacquer. I shot 5 coats of Dupont 99S Diamond Black and covered that with 5 coats of Dupont 380S Clear. Now remember, lacquer goes on much thinner than the newer hardened enamel. 5 coats of lacquer is probably the equivalent of 2 to 3 coats of the more modern paints.
Before you make the decision on staying with lacquer here are a few things to think of.
Lacquer is being phased out even as we read this and in the future you may not be able to get it for touch ups or panel repaints. I know PPG says they're going to continue to make it but if they don't make a good return on their investment they'll drop it like a bad habit.
Lacquer is brittle and dries continuously. Even a garage queen will be more susceptible to cracking, and defects in the paint due to natural and man made issues. Bird droppings can etch the paint in minutes and we don't even want to talk about some of the chemicals we use in the garage and what they can do to it.
It's a high maintenance finish. Every year you will be compounding and using swirl and haze remover to keep the shine up. I remember my dad, back in the early 50s compounding and Simonizing his cars every year by hand. This is the technology were talking about.
Even if your original lacquer has held up beautifully over the years consider that the paint you will spray will not be like the paint used at the factory. Factory paint was formulated different than what you buy on the aftermarket because it was baked in ovens and also needed to be dry and ready to ship in a much shorter time than a repaint would.
I can tell you honestly that owning a black lacquer car is challenging and I've put 100 times the work into maintaining it as you see in the picture as I have in my daily drivers. Is it worth it? For me, yes. I like the idea of being able to easily spot repair any chips or scratches and for me there is nothing like the depth and reflectivity of a lacquer finish. It's also a very safe paint to spray. I really didn't want to get into the whole spacesuit thing required when using the newer paints.
You'll have to make your own choices on what you want to do. Good luck whatever choices you make.
Old Oct 27, 2006 | 12:36 PM
BKbroiler's Avatar
BKbroiler
One suggestion about primer. After stripping my car with Captain Lee's, we used a primer/sealer, then sanded, then used primer surfacer and more sanding. Then base coat/clear coat, all DuPont products. We thought the sealer effect might be helpful in preventing any future problems. So far, so good.
Old Oct 27, 2006 | 12:44 PM
Jud Chapin's Avatar
Jud Chapin
I would not use lacquer. In fact, you may not even be able to get in your state as many have outlawed it. Actually, even if you can get it, it is not the quality it was when our C3's were originally painted. PPG has a tech line and they would be happy to talk to you about it. The paints of today are far superior to any lacquer.
Old Oct 27, 2006 | 01:00 PM
Jud Chapin's Avatar
Jud Chapin
Tried to get the tech no. for you but all I could find is the web site:
http://www.ppg.com/car_autocoat/default.htm
Perhaps you can find a no. there or use their email "contact us".
To Capt'n Lee's stripper experts needed....
Old Oct 28, 2006 | 09:46 AM
75coupered's Avatar
75coupered
BK, agreed, I'm sanding as much roughness and residual paint on the body now but plan on using a good primer/sealer and then highbuild filler primer sand etc., so far the body is in really nice shape and there are only some very fine scratches to fill in which the primer should take care of.
Vettefixr, thanks for the info, like you I don't have the interest to invest in a space suit, nor will I ruin my scuba gear shooting BC/CC, so unless I can find someone that has the equipment and interest to shoot the car for me at a good price I will consider the enamel. An Black is beautiful but a paint to maintain in any color especially lacquer
I've shot lacquer before, and I can find it quite easily, PPG, Dupont, House of Colors and several other retailers still offer it... not sure for how long though.
Jud, Vettfixr and all:
Does anyone know how good are the single stage enamels? My color dark red, more like a small flake metallic ruby red and it comes in both single stage lacquer and enamel, has anyone used the enamel for metalics before? What were the results?
Thanks again
Old Nov 18, 2006 | 04:18 AM
war vette's Avatar
war vette
Just about any single stage urethane from a reputable company will be good. Dupont, P.P.G., Sikkens, Glasarut
Old Nov 21, 2006 | 11:22 PM
ctrain22's Avatar
ctrain22
Where can you get Capt Lee's?
