Help reinstalling the AC
Old Oct 26, 2006 | 01:44 AM
GreenRocket's Avatar
GreenRocket
Default Help reinstalling the AC
The AC in my 69 was taken out by a previous owner. I am thinking of getting it back in. One thing that is missing is the bracket for the compressor. Can someone help me with photographs to show how the compressor is installed. Also, any tips on the reinstallation witll be appreciated.
Old Oct 26, 2006 | 07:01 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
One option is to pick up a GM assembly manual for a '69 and that will provide detail graphics of how the system is put together.
Old Oct 26, 2006 | 07:29 AM
markdtn's Avatar
markdtn
The Shop Manual is also a good source. Everyone who does any work on their car should have the year-specific GM shop manual. Available from the catalogs, Ebay, maybe still from helminc.com
If you have a Corvette Central catalog, they have good diagrams on that type stuff too.
Old Oct 26, 2006 | 09:14 AM
75 Red Vert's Avatar
75 Red Vert
Here you go
Randy
http://www.zip-products.com/Zip/dept...6C998A296C2C68
Old Oct 26, 2006 | 11:41 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Order the '69 AIM when you order the mounting kit suggested by 75 Red Vert. The AIM has installaton pictures and assembly notes for the entire AC system. Now would be a good time to convert to R-134a.
Check to see if you still have the stud on the RH exhaust manifold. Stock bolt was pulled, stud installed. AC bracket uses the stud.
Old Oct 27, 2006 | 12:38 AM
GreenRocket
Thanks for all the advise. Appreciated.
I have just ordered a copy of the AIM from ZIP.
To Help reinstalling the AC
