Radiator Swap
Old Oct 26, 2006 | 04:04 PM
Fubba's Avatar
Fubba
Default Radiator Swap
Hey guys,
I just ordered a new aluminum radiator from DeWitts with the dual SPAL fans kit for my '71 with a 350 and auto transmission. It should be here next week sometime (I'm hoping...I'm ready to start driving again). I'm going to try to post pictures and steps as there are so many questions as to how to do it as far as installing and wiring. This is my first time taking the radiator out of the car, so I would appreciate any tips and suggestions from anyone who's willing to give them. My main question is once the new radiator goes in, I won't need the shroud or anything. It seems like the shroud takes up a lot of room and helps direct the air throught the radiator. Will I need to seal the radiator up on all sides to keep it flowing through the radiator? If so, how did you do it? Thanks, and I'll keep you posted as I move through this project.
Old Oct 26, 2006 | 04:26 PM
Durango_Boy's Avatar
Durango_Boy
Yes, you will want to make sure the only place air goes through is through the rad itself. Most of the readily available Corvette parts catalogs will offer rad seal kits. Any other gaps you can be creative, and go to a Lowes or Home Depot or something and get some kind of weather foam stripping. The thicker the better. Just do what you can to block everything but the opening of the rad itself.
Old Oct 26, 2006 | 05:15 PM
Xakk's Avatar
Xakk
I don't know how well you can see from these pictures, but this should give you an idea of where all the seals should go. I used high density pipe insulation from Lowes to fill in the places the seal kit misses.
Unfortunately, I haven't taken any pictures of the seals between the radiator support and the hood, but that's also an important.
Hope this helps.
Old Oct 26, 2006 | 07:43 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Hey guys,
I shipped it today, you should see it in GA on Wednesday.
Old Oct 27, 2006 | 01:13 AM
Fubba's Avatar
Fubba
Awesome! Thanks Tom.
Old Oct 27, 2006 | 10:41 AM
Durango_Boy
Xakk - Did you make that bracket for the fans yourself? It looks like a fine job with a metal break and a drill press.
Old Oct 27, 2006 | 11:51 AM
Xakk's Avatar
Xakk
Nope. The bracket came from DeWitts. Tom mounted the fans to the radiator before shipping.
Old Oct 27, 2006 | 03:40 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Thanks! You can have a set too! I sell them for $40/set and that includes all the hardware to mount a set of spals. The Be-cool kits will cost 4x that. The full kit (SP460) has them included.
The bracket is simple and the concept is simple. That is why I preach about the OE Hat channel design and try to create an industry standard for mounting accessories. Factory GM C3 rads uses them, Griffin uses them, and we use them. They are much stronger than two bend channels and if everyone used them, our bracket would fit every radiator.
Old Oct 27, 2006 | 03:44 PM
Durango_Boy
Very nice indeed. Seeing as how I have a Corba fan to use when the motor swap goes through I will be using those slide-through-ties. I have five mounting holes on that fan, so I hope that will be enough to keep it secure against the face. Obviously I will use the neato foam washers to minimise vibrations and harsh friction.
Old Oct 27, 2006 | 05:46 PM
Fubba's Avatar
Fubba
Next question...what holds the radiator support on? I've already got the radiator and fan shroud out. I've got all three bolts in each wheel well taken out. It still isn't wanting to budge. Is there anything else that could be holding it on? Maybe I'm just not seeing where it's binding.
Old Oct 27, 2006 | 05:52 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
I think you have two more on the bottom cross memeber
Old Oct 27, 2006 | 06:09 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
And that funky little brace that runs up between the headlight mounts.
Old Oct 27, 2006 | 06:49 PM
Durango_Boy
Is that on his year Vette?
Old Oct 27, 2006 | 07:09 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
I realize a lot of people do this but I wouldn't. The reason I say this is because you are actually "hanging" the radiator on the horizonal cooling tubes. These tubes are only about .018 thick and that fan package looks heavy. Why not fab up a couple strips of metal that hook over the top of the radiator and pick up a couple of the mounting holes on the fan?
Old Oct 27, 2006 | 07:14 PM
Durango_Boy
I thought of that, and I might. The fanitself really is not very heavy. The frame is light, and the motor and fan are the heavy part. It's frame structure would make it very hard to fab up the brackets...I would have to make five of them.
Old Oct 28, 2006 | 11:47 AM
Fubba's Avatar
Fubba
So after I found and got all the bolts out of the radiator support, I realized the two lines running to the A/C condenser are going through the support in the upper passenger side corner. My A/C works too. Should I just leave it alone at this point? I would like to get it out and get it painted, but if it's going to be some huge deal, then I would rather not. That beautiful DeWitts radiator will make up for it I suppose.
Old Oct 28, 2006 | 11:54 AM
Durango_Boy
If you dissconnect thos elines the system will de-pressurizem, and you will have to have the system flushed and filled by a shop. If the A/C works good and cold I would leave it alone for now.
To Radiator Swap
Old Oct 28, 2006 | 11:58 AM
Fubba's Avatar
Fubba
I figured as much. I fixed the A/C last summer, and I don't want to do it again...lol. Thanks for the help.
Old Oct 28, 2006 | 03:51 PM
Durango_Boy
When you say fixed, did you upgrade to 134 or are you still old school?
Old Oct 28, 2006 | 09:47 PM
markdtn's Avatar
markdtn
You will have a fan turning on and off and thus twisting against those ties. Do you really want something twisting against the tubes in your radiator? I would really think hard before mounting a fan that way. A trans cooler is bad enough, but it doesn't move.
