Radiator Swap
Old Oct 28, 2006 | 10:23 PM
Durango_Boy's Avatar
Durango_Boy
Originally Posted by markdtn
You will have a fan turning on and off and thus twisting against those ties. Do you really want something twisting against the tubes in your radiator? I would really think hard before mounting a fan that way. A trans cooler is bad enough, but it doesn't move.
I will consider lots of options. I have until spring to decide. The problem is the design of the fan's frame. It's hard to make a single bracket for. I may make a top, and bottom bracket, and use the slide-ties for the other three mounting points.
Old Oct 29, 2006 | 01:05 AM
Fubba's Avatar
Fubba
Originally Posted by Durango_boy
When you say fixed, did you upgrade to 134 or are you still old school?
Still running the old stuff...just had to replace a few parts in the system. Cools quickly and efficiently though.
Old Oct 29, 2006 | 09:33 AM
Durango_Boy
Good deal. When it does go warm on you, I'd suggest the switch to 134. It's a goow swap to make the further we get away. I've heard that 134 is gonna be done away with in favor of another synthetic coolant in the next few to five years. That could be interesting.
Old Oct 31, 2006 | 04:30 PM
Fubba's Avatar
Fubba
Another question. Since I can't get the support out, where do the seals go on it? There are four. Would it be easier to put these on with the radiator in place, or should I wait for them to come in before installing the radiator?
By the way, I got everything from DeWitts yesterday evening, and it all looks GREAT!!!
Old Oct 31, 2006 | 04:45 PM
Durango_Boy
You'll want the foam seals first. Install some on the rad, and others on the support for the hood. They should come with instructions.
Old Oct 31, 2006 | 04:46 PM
Fubba's Avatar
Fubba
Ok, so I just figured out that the seals block off the air from going in between the support and the radiator itself, so the radiator will need to be in there I'm guessing.
Tom told me that 71s did not have an expansion tank. Do I need to just run a hose straight down from the overflow on the radiator?
Old Oct 31, 2006 | 04:47 PM
Fubba's Avatar
Fubba
Beat me to it. I just ordered the support seal kit from Zip. I'm guessing it's what I need.
Durango_Boy
Either that or down to the ground like old-school hot rodders did.
Old Nov 1, 2006 | 09:08 AM
swensonm's Avatar
swensonm
Default Hijack
Fellas
I have a 74 4 speed
Trying to install a Dewitts rad. I have posted in General and I have received help but no luck. I cant get my rad back in.
Maybe I will change to Spals but I have to spend the additional cause I cant get the shroud in.
I have:
1. unbolted the shroud and moved it forward as far as possible
2. tried radiator first...shroud wont clear the upper control arms
3. shroud in then the radiator....cant get the lower radiator inlet past the upper control arm.
4. holding the shroud and radiator together and trying install. could not get the shroud past the upper a frame on the drivers side after tilting the radaitor and shroud to clear water pump and radiator inlet past the upper a frame.
any other tips here ...really getting frustrated
Mike
Old Nov 1, 2006 | 09:10 AM
Durango_Boy
Originally Posted by swensonm
Fellas
I have a 74 4 speed
I have:
Mike
Have you contacted Tom DeWitt? He being the seller is going to have the best advice for you. He is also super nice and will give you all the tech support you need.
Old Nov 1, 2006 | 11:57 AM
Fubba's Avatar
Fubba
Fellas
I have a 74 4 speed
I have:
Mike
Have you taken the three bolts out of each side of the radiator support? These are accessed in the front of each wheel well. Once you take these out, the support will slide forward. Until you do this, I doubt you will be able to get it past the control arm.
Old Nov 1, 2006 | 02:22 PM
swensonm's Avatar
swensonm
Default rad
Yeah I have moved the support forward....
I just am very frustrated I want to get on the road again.
It cant be as hard as I am making it!
Sorry for jacking your thread....
Mike
Old Nov 1, 2006 | 03:31 PM
  #33
Green76's Avatar
Green76
Fellas
I have a 74 4 speed
I have:
Mike
swensonm,
The easiest way to install radiator is by:
1 Remove hood (mark where hinges are located for ease in installing).
2 Remove radiator fan (4 nuts).
3 Remove upper and lower radiator hoses.
4 Unbolt radiator support (3 bolts each side and 2 on the bottom and support rod, remove radiator support from car).
5 Clean up radiator support and install new rubber seals while it is out, now lay support on floor and install new radiator on top of support and bolt together, next clean up fan schroud and install new rubber seals, now lay fan schroud on top of radiator and bolt it together with radiator and support.
6 Now lift the whole assembly (support, radiator and fan schroud) into the car it will slide in as one unit, before bolting the support in place install support rod in first then install all bolts.
You don't have to replace all rubber seals if in good shape but I recomend it, do it right the first time and you don't have to do it again later..................
Old Nov 1, 2006 | 07:38 PM
  #34
swensonm's Avatar
swensonm
Default Green
green are you on right now? would like to calll and talk to you
Old Nov 2, 2006 | 01:36 PM
  #35
Fubba's Avatar
Fubba
What source should I use for the 12V ignition wire? I've heard of people running it to the ACC or IGN on the fuse box, but I've never hooked anything up here before. Is this the best source, or can I pull it from somewhere else? If it is the best source, how do I do it?
Old Nov 2, 2006 | 04:33 PM
  #36
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
Old Nov 3, 2006 | 08:50 PM
  #37
Green76's Avatar
Green76
swensonm
I sent you a private message.
