A/C Help 1980
Old Oct 26, 2006 | 09:34 PM
narlyass's Avatar
narlyass
5th Gear
Default A/C Help 1980
A/c blows cold but it blow out the floor vents only ?? any help
Old Oct 26, 2006 | 10:05 PM
Jerky_san's Avatar
Jerky_san
o-o well don't think i know a ton but since no one else has responded. I think it sounds like a vac line isn't doing its job.
Old Oct 26, 2006 | 10:20 PM
SIXFOOTER's Avatar
SIXFOOTER
the vac selector in the console ususlly leaks, you may have to take it apart, clean and lube it and reassemble using a screw and nylock nut. It is assembled with a rivit now
Check the vac line from the manifold to the firewall also, it is a small black line that goes thru a large gromet on the firewall
jayr's Avatar
jayr
On the back of your heater and air control is a round plastic with a bunch of vac. holes to it. You might have a bad hose in that bunch but
my 81 had a leaking rubber gasket in the piece that the hoses connect to. It has been a year since I fix my but I think there is one screw that
keeps the unit together. If I remember correctly, I shim the screw to put more tension on it and valseline the rubber. I did not mark relationship
of the rubber with vanes in it and took me over an hour getting it in the
correct position. I would hold it together with one hand and move the
lever with the other untell I found the correct position. Than when I
put the fastner on it would leak again. I finally found the right flat washer to have tension 360 degree around. A few days later I found
one in a corvette parts catalog listing the gasket separately for 26.00.
Thinking of buying one just in case this goes to hell again.
To A/C Help 1980
