C4 Serpentine Setup
Easy stuff first
1. What bolts do I need to mount the C4 brackets? (Length, diameter, thread)
2. Which bracket holes correspond to which bolt holes in the block and heads
3. Serpentine belt routing (and size(s))
Parts that I have (acquired through 3 Ebay auctions)
1. Lower Alternator/PS Pump bracket (2)
2. CS130 Alternator w/pulley
3. PS Pump w/pulley (2 pulleys)
4. Waterpump w/pulley (2 pulleys)
5. AIR pump (no bracket or Pulley)
6. Breathless Air Pump eliminator bracket and pulley
7. AC Compressor Bracket
8. AC Compressor w/clutch/Pulley (2 - 1 from a 90, 1 from an 84)
9. idler pulley
10 Crank pulley
Stuff that I need.
1. PS reservoir
2. PS hoses - going to need custom setup to run 71 Power steering (I am starting to collect pieces for a jeep box conversion, just not there yet).
3. Custom AC hoses to fit the later model Compressor up to POA valve system and complete R134A conversion
Additionally, I realize that the waterpump I got is probably only good for core value at Autozone. While I'm at it I ought to go to a 140 amp alternator, might as well go polished or chrome. Might as well put a new seal kit in the PS pump while it easy to get to. Did anybody say March polished/Billet pulleys for the crank, waterpump, and power steering? if so I heard you. My local powder coat guy will probably get to play with the lower brackets. I already have a new Dewitts Direct fit aluminum radiator to go in, and some Camaro/TA dual electric fans.
So can anyone help out with pics, diagrams, bolt specs, sources for custom hoses, correct bolts? I would appreciate it. I have researched polished waterpumps, chrome and polished alternators, as well as underdrive pulley systems but I am still open to suggestions.
And of course I will take pics to document this project and will sell off the surplus parts here on the forum as well as the good old C3 fan, fan clutch, alternator, PS Pump and A6 compressor.
Orville
OH, all the bolts are SAE on the threads.....heads maybe differant, but between 1/2 and 9/16, and 13-14 mm who cares??
Did you have any clearance issues with the front cross member from the crank pulley or power steering pulley?
BTW for all who have responded thanks! More help here in a few hours than in 2 days in the C4 forum.
Keep it coming!
Orville
back in the daze of film photography//remember THAT??
eh...
anyway....use standard SAE/American inch standard bolts...nothing new or dramatic....and i'ts a bolt on, NO clearance issues with anything....
you gotta remember, Gm engineers typically use a test mule....a current production car, for new development work...so in the case of the C4, it was an '82 or 83 vette....ONE still existing...
I think that is the reason it fits so nicely...THAT and the C4 chassis design is so similar, in reality...transverse spring, cross support in front of engine, etc....
Bolt Diameter, length, thread, tensile strength,
I know it should interchange to any gen 1 block and heads. What source? Summit and Jegs have nothing.
some of the older heads will be missing some holes for accessory mounting, the '70's heads will typically be missing the upper centermost bolt hole for say the a/c compressor mount bracket...I just leave it out and i'ts fine...got 3-4 more in front, plus the brace to the rear exhaust manifold.....
the bolt penetration into the block should not be less than 1/2 inch in any case, and 5/8 is more like it...two more threads...check depth first, obviously....IF I can't find the exact bolt, I use washers/spacers to make something work, go back and cover the base later, if necessary...mainly due to appearance...
but my daze of showing the car are far over with, today it's a street driver....quicker than most, not even 1/2 fast as others....
I believe most of the fasteners on the serpentine setup itself are SAE metric, 8mm and 10mm. The bolts that attach the brackets to the front of your 71 engine will not be metric of course and should be 3/8-16 (I think). I'm thinking you will want at least 3/8-16 x 1" grade 5 bolts. These should be available at Lowes/Home Depot.
Any GM PS pump will bolt in. Your 71 pump has the same mounting as the later "metric" pumps however if you use a later style (with metric fittings) you will have metric fittings on the Jeep box. This will make the swap easier.
Call around to salvage yards and see if anyone has a C4 with a complete motor. Like a pick and pull kind of place. Then, maybe you pay a few hundred, but you can take the whole thing.
What is it you still need info on?
1. PS reservoir (& where does it mount?)
Polished waterpump, or over the counter replacement alu pump?
Stick with the 105 amp CS130, or go to 140 amp, 200 amp? - Polished, chrome?
I know that wiring connectors are readily available for attaching a CS130 in to the stock wiring harness, but what about the ac compressor clutch hookup?
The alt. The CS144 is less likely to overheat, and will provide you with lots of power. The CS130 isn't bad if you don't run it too hard. A stock Vette with a CS130 would be fine.
The A/C compressor on both uses a one wire turn on. It's grounded through the bracket, and a single wire feeds the clutch to engage it.
I have a '84 p/s reservoir, but I used to have the '90 style mounted to the fenderwell.
I used the '84-85 style alternator because it plugs right in and they are more reliable than the later ones. The lower bracket is the same for both. I also got an air pump eliminator kit from Breathless. Get it to match the alternator you choose.
Made a high pressure p/s hose with the stock C3 hose and a C4 hose joined with a flare fitting. That way you can swivel it in the middle to avoid kinking it.
The '90 Nippendenso a/c compressor is a nice part. Unfortunately you have to build a hose for it because the stock hose is not the right length. I had my local CarQuest build it for me. No big deal.
Send me an E-mail address to send photos to and I will send tomorrow.
Let me know if you want me to email the layout to you. I am more than happy to help. I have the factory service manual so I will do what I can.
My 91 is already put away for the winter
so I can't go look at it.I owe you guys a lot. Just let me know if I can help.
Dan in Austin
You have PM. Thanks.
