tach drive distributor ?
Old Oct 29, 2006 | 09:50 PM
JustForFun's Avatar
JustForFun
Default tach drive distributor ?
my 72 has a worn/broken tach drive gear inside the distributor. what is the servicable part? can you replace on the gear, or does the whole distributor shaft need replacing? availbility on these parts?
Old Oct 29, 2006 | 09:55 PM
...Roger...'s Avatar
...Roger...
The whole shaft
Old Oct 29, 2006 | 10:00 PM
JustForFun's Avatar
JustForFun
thanks!
any upgrades that should be done to the distributor since its out?
Old Oct 29, 2006 | 10:07 PM
Donald #31176's Avatar
Donald #31176
Check the inside of housing to see whether the drive gear has dug a hole . If so you must install a thrust bushing or youll be replacing the shaft and drive gear real soon.
To tach drive distributor ?
