C3...anemic HP...Help
I have a 350, brand spankin new Edelbrock Performer intake & carb, an aftermarket slightly beefier cam & shorty headers to a 3" Y pipe which is married to a free flow 3" cat, from the cat back it's true 3" exhaust to the magnaflow 40's.
I was thinking that the car would at LEAST get 330HP.
But, on the MustangDyno I only pulled a 281. Three times in a row.
.Andy
My 89 can run circles around my 76. If you have a Mid-70s C3 then you are right in the middle of the Smog era. I think some of the motors in this time frame only had around 220HP at the crank. With a 20% due to drive train you are right about where you should be.
With the changes you made it should have been a bit higher but it depends on what else you have going on. The shorty headers, depending on the maker, are at times no better than the stock iron headers. Switching from single exhaust to dual exhaust might help. Since you have allready went down the path of getting the air out of the car you need to look at how you are getting in into your motor.
Higher flowing carb and higher flowing heads will help a TON. The heads are probably what is really killing you right now. If you are running the stock heads then that is what I would change next. Adding the intake and exhaust that you have will not help at all if the heads can't get the gas into the cyl.
Tim
I was thinking that the car would at LEAST get 230HP.
But, on the MustangDyno I only pulled a 181. Three times in a row.
I mean, my wifes saturn has a Yamaha DOCH V6 which will pull a 210hp on the dyno.
What I want to know is, how can I get my 350 to perform better?
It shouldn't be THAT hard to get 250hp out of a SB chevy, right?
Andy
Your car should make more power than that ??
How does it run ??
WHat kind of torque did it make?
What stall converter are you running?
DO you have REALLY tall tires in the back??
What is your timing set at ??
And we all assume you are running factory heads...but you should make more power than 181 ?? guessing about 8.5 to 1 compression. That 3in exhaust doesn't help you...with a mild motor
Andy
Theres no way a mid 70's stock is going to push 275 plus HP at the crank.....and I suspect those who dropped in a 330HP GM crate would be unpleasantly surprised at the HP reading on a CHASSIS dyno, at least with a slushbox
Here's what it looks like.
It's a 1980 with a 350cu in. It is a new (completely remanufactured) engine with 6,000 miles on it.
I'm not sure what the cam size is but the mechanic who did the work did have to advance the timing to cooperate with the cam. I wish I knew.
But, yes...It does have the original heads. Also, on the dyno it was pretty clear that the primaries are running too lean and the secondaries were very late in opening (bad or weak counterbalance spring?). But, when the secondaries did open, they were too rich.
Oh...the sticker came with the air-cleaner
it was the only model we could fit in their without cutting.Since I never use the A/C could I just simply remove the pump & cap the hoses?
Andy
I see you are running an 80 shark. Be sure you have the right advance curve; you can pick up alot of power with the right advance curve. And the car will seem underpowered if you are running the stock timing/advance. I paid $250 to a tuner that had a dyno to lay a nice new advance curve down on my Accel Performance Replacement distributor; made a big difference.
what air/fuel ratio numbers was your car producing? That will tell you if you need to lean/richen which can also free up some power.
I would pay somebody to adjust your carb and timing...
that alone should give you about 15-20 rwhp... sounds like your car does not perform well.
bone stock smog L48 should make about 140-150 rwhp with 20 drive train loss.
a new cam, intake, carb , true duals should bring you to about 200rwhp...get some long tube headers about 10-15rwhp and decent set of heads with a small chamber 58-64 cc and you should be over 250-260 rwhp.
I really appreciate this thread guys.
Andy
In summary,
L-48: under 170 rwhp
cam/intake/exhaust: around 200 rwhp
heads/headers: 250+ rwhp
Assuming the pistons are stock.
