Alignment Issues
Old Oct 30, 2006 | 05:28 PM
superstingray_1975's Avatar
superstingray_1975
Default Alignment Issues
ive got a '75 stingray which i have lowered, and now i have a tow problem in the rear and a camber problem in the front. there are two or three 1/16 shims on the trailing arms are on the inside so i dont have very much adjustment as far as remedying tow out. In the front i have all of the shims out and the top of the tire is still leaning in. undoubtably it is from lowering the cars stock ride height. any suggestions would be greatly appreciated.
Old Oct 30, 2006 | 05:38 PM
zwede's Avatar
zwede
How low is it? If it's slammed into the ground, nothing will fix the alignment.
For the front camber you can get offset cross shafts. Moog makes them, sold by (among others) NAPA.
Old Oct 30, 2006 | 05:59 PM
superstingray_1975
i have the car pretty low. also can i take all of those shims out.
Old Oct 30, 2006 | 06:02 PM
NHvette's Avatar
NHvette
Vansteel can set you up with an offset upper front shaft for decent money.
That's where I got mine ... faster than ordering locally and same price.
If you have rubber bushings, this will be a big chore.
With poly, they are out and shaft changed in less than 1 hour.
In the rear, it could be worn rear yokes or slightly bent trailing arm.
That will take some investigation to confirm. Do you get movement
of the rear wheel when jacked up ... at 12/6 Oclock but not 3/9 Oclock?
Old Oct 30, 2006 | 09:21 PM
SIXFOOTER's Avatar
SIXFOOTER
In addition to the abovem Smart Struts might help get the rear in line.
Old Oct 30, 2006 | 10:14 PM
Glassbowtie77's Avatar
Glassbowtie77
When I rebuilt and lowered my frontend I bought 550 lb. springs and offset control arm shafts from VB&P and I have no alignment issues. Ask for Gary or Pattie when calling there, they are real nice folks, very friendly and knowledgeable. They can help you get it right.
To Alignment Issues
