manual light switch
Old Sep 19, 2001 | 05:36 PM
ALIEN's Avatar
ALIEN
Default manual light switch
cant find where the button is to put up my lights on my 1981 :confused:
Old Sep 19, 2001 | 05:43 PM
Ben Taylor's Avatar
Ben Taylor
Default Re: manual light switch (ALIEN)
you can either pull out the headlight **** all the way, or there is a vacuum switch underneath the steering wheel by your legs, it's a tiny black **** that you pull down. Since it's vacuum the engine has to be on for it to work.
Old Sep 19, 2001 | 05:48 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Hmmmm, 81, you should twist your turn signal maybe....
Old Sep 19, 2001 | 05:51 PM
ALIEN's Avatar
ALIEN
Default Re: manual light switch (Ben Taylor)
that black **** is what i can't find, is it hard to find or is out in the open?
Old Sep 19, 2001 | 05:59 PM
Ben Taylor's Avatar
Ben Taylor
Look where your hood release is, and then go 6 inches to the right of that, and there it is.
Old Sep 20, 2001 | 11:24 AM
Ken74Conv's Avatar
Ken74Conv
I also had problems locating the vacuum switch. Turns out that the **** was broken off flush with the panel covering the steering column. It should be there and it will have (2) vacuum hoses connected to it.
Old Sep 20, 2001 | 12:20 PM
Koz
Guest
Posts: n/a
There is a cover plate right below the steering column. Take out the 4 screws and the switch should be attached to that cover. That's how it is on my '80 anyway.
Old Sep 20, 2001 | 03:32 PM
daniel77350's Avatar
daniel77350
Default Re: manual light switch (Koz)
I heard stores about it being broken off...the best way to find it is sit on the door sill and look up under there...you'll see it even if its broken.
Daniel
To manual light switch
