vibrations through all rpms range...
Old Nov 1, 2006 | 12:33 PM
panic's Avatar
panic
Default vibrations through all rpms range...
i'm just coming back from a cruise on the motorway...on a hard acceleration fm 3rd to 4th at about 5.000 rpms i've noticed an unusual and pretty hard vibration, you can notice it mainly at the trans shifter, it reduces going at lower rpms but does not disappear completely...also, on a standstill rush i've noticed (going back home) some 'movement' right in the centre of the undercarriage...like if there was something loose (driveshaft or trans).
the car has a 570hp (530tq) engine and an uprated rear end (diff/4.11 gears/3.5'' half shafts/HD TA) built by van steel with many tom's items...driveshaft is stock (2.5'') and trans is a loyal and fearless t-10 4 speeds...
i'm afraid there is something out of place down there, where should i start looking?
thanks/Giu
Old Nov 1, 2006 | 12:50 PM
genuine1980's Avatar
genuine1980
If it was me I would start by checking motor mounts, tranny mounts, diff mount, and u-joints.
Old Nov 1, 2006 | 12:52 PM
pws69's Avatar
pws69
thanks/Giu
Did you get that driveshaft rebalanced for the new setup? If not, find a good driveline shop and do that first.
Old Nov 1, 2006 | 12:59 PM
panic's Avatar
panic
no, i didnt...
but it's about a month i'm driving with no problem nor vibration whatsoever...this new iussue just started 2 hours ago.
Old Nov 1, 2006 | 01:01 PM
75 Red Vert's Avatar
75 Red Vert
Might have lost a weight off the drive shaft - if you had a weight in the first place. Then check U-Joints.
Old Nov 1, 2006 | 01:09 PM
...Roger...'s Avatar
...Roger...
If you have a fan driven by the water pump check both of them for loosness and wobble.Make sure your harmonic balancer didnt move.
Old Nov 1, 2006 | 01:17 PM
wfo76's Avatar
wfo76
a worn crankshaft pilot bushing can also cause this.
1stC3Vette's Avatar
1stC3Vette
To resolve this issue with my brother's '76, he had to replace the rear hub bearings that were bad on one side and going bad on the other. This was done after the U-joints were replaced.
Good luck,
Dino
Old Nov 1, 2006 | 01:27 PM
panic's Avatar
panic
hope this is not the reason, no, i'm pretty sure it isnt, the engine runs on silk, it's fully balanced, never had a prob.
it's something coming fm the trans or driveshaft, definitely
Old Nov 1, 2006 | 01:40 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
double check it. I seen people pay out the rear to shops
to find a vibe, 99% of the time the driveshaft went bad.
Old Nov 1, 2006 | 03:13 PM
pws69's Avatar
pws69
no, i didnt...
You really should. Remember that you are now spinning the drive shaft faster (perhaps considerably depending on the previous ratio) than you were before for any given road speed and you were talking revs of 5K plus, so it certainly could NOW be an issue. As someone said, perhaps you threw a weight (could have been loose and now with the higher revs, finally let go), or some other driveline problem has surfaced. I believe it's worth a check.
Old Nov 1, 2006 | 04:30 PM
panic's Avatar
panic
thanks for the advices and infos, i'll summarize everything said and think will start checking the driveshaft...giuseppe
Old Nov 1, 2006 | 04:44 PM
vetteaddic's Avatar
vetteaddic
You said you can feel it at a stop ,in netrual or running down the road,check trans mount,
I had a bad pilot bushing or someone installed the wrong one and you could feel it at high rpms only,but yes check driveshaft u-joints,trans mount,motor mounts and rear end first before diving in the clutch pilot bushing.
Old Nov 1, 2006 | 08:09 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
thanks/Giu
But if it isn't those I would bet its the T-10 trans input shaft bearing. The BW T-10 is rated for about 375 ft lbs of torque. The ratings are for that amount of torque continuous for 24 hrs. A fourth gear upshift is going to a 1 to 1 ratio. All of the torque is loaded directly onto the input shaft bearing. None to the cluster. A 5000 rpm powershift to fourth gear puts an instant, terrific shock load on that bearing. The tire slip that cushions the shock does not happen as easily in the higher gears so the instant driveline shock is greater. The weak link always breaks. I know you like 4 speeds not the 5 speed so check into an Autogear Super M-22 Rockcrusher. Direct bolt in. It will take whatever you throw at it. I can connect you with a good supplier if you need one.
To vibrations through all rpms range...
