HELP! Vette No Start, Starter Problem?
Old Sep 19, 2001 | 10:05 PM
NVRL8's Avatar
NVRL8
Default HELP! Vette No Start, Starter Problem?
Went out today to start the car (details in sig) this afternoon and it wouldn't start. I didn't even get the dreaded click of death (solenoid attempting to engage).
I turn the key and I get nothing. All other electrical on the car functions correctly. (see note below) 6 monthsago I installed a CVR protoque starter from Jegs and it has performed flawlessly since then.
Here's what I know:
The battey is fresh and strong (chargered current battery and swapped with another--stikll no luck)
Solid ground, solid + connection at starter, solid ignition connection at solenoid
Solenoid is seeing 12v when key its turned--confirmed at solenoid
Getting power at coil
Here's what's odd:
Key buzzer not buzzing when key in ignition and door open (new problem)
Ammetter show huge current drain when tryiong to start car, but no physical action
Here's what I think:
The starter or solenoid is frozen. Why else would I have a huge current draw with no action while trying to start the car. The only problem is that it started perfectly less that a week ago and has no previous indication of failure.
And if the starter is frozen wouldn't I still hear the solenoid click as it receives power?
I'm trying not to tear the whole car apart to fix this one. Is there anything I'm missing? Any advice?
Old Sep 19, 2001 | 11:02 PM
jerryp58's Avatar
jerryp58
Default Re: HELP! Vette No Start, Starter Problem? (NVRL8)
Tap on the starter with a hammer a couple of times and then give it a try. If it works, then go buy a new starter (or rebuild yours).
Of course, you could take the starter to a local auto parts store and have it tested for FREE.
Oh... "And if the starter is frozen wouldn't I still hear the solenoid click as it receives power?", I don't think so.
[Modified by jerryp58, 10:04 PM 9/19/2001]
Old Sep 20, 2001 | 12:02 AM
RJR99SS's Avatar
RJR99SS
was this a hot start? or was it the first start of the day? well, to check the starter, hotwire the sucker. just lay a screwdrive across the the power and the starter terminals, you know that old trick. if the starter goes then, well you're problem is elsewhere. if it dosnt go....then its a safe bet its your starter.
Old Sep 20, 2001 | 08:12 AM
NVRL8's Avatar
NVRL8
Default Re: HELP! Vette No Start, Starter Problem? (RJR99SS)
It was the first start of the day (week). And I did take srewdriver and short the solenoid to the primary coming in. And nothing more than a spark, no noise of any sort.
I've never had a starter fail in 6 months, a mini starter nonetheless, with no previous warning.
The only thing throwing me for a loop is the key warning buzzer not working, I didn't know if there was a relay under the hood that could be link to the ignition.
Cheers,
be
Old Sep 20, 2001 | 09:16 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Sounds to me like a solenoid problem. You should hear the solenoid if it is getting power. Take it to Auto Zone or somewhere that tests them for free and let them show you if it is the starter. :confused:
Old Sep 20, 2001 | 06:46 PM
JB's Avatar
JB
St. Jude Contributor
Default Re: HELP! Vette No Start, Starter Problem? (Eddie 96)
Nope, can't be the solinoid--when he jumped across the contacts, he took the solinoid out of the picture. The buzzer sounds like another problem to me--from the description, really sounds like a bad starter. I'd pull it and let them test it at the parts store.
JB
'78SA
Old Sep 20, 2001 | 09:47 PM
NVRL8's Avatar
NVRL8
Default Re: HELP! Vette No Start, Starter Problem? (JB)
Thanks for everyone's help. Even as lazy as I felt about this, I removed the starter and had it tested.
That solenoid worked perfectly, the starter motor was bad. Although it's only 6 months old, JEG's won't cover it under warranty. I have to go through the manufacturer--CVR. They were closed by the time I called.
I still can't believe that it failed after only 6 months with no warning.
Thanks for your help.
be
To HELP! Vette No Start, Starter Problem?
