Idle...
Old Nov 1, 2006 | 05:15 PM
jerrylee's Avatar
jerrylee
Default Idle...
Hey guys after driving around for a while my idle gets real low like she wants 2 stall...I also noticed some dark smoke coming from the exhaust..Is this signs of a idle adjustment or something else...Thanx...Jerrylee...
Old Nov 1, 2006 | 05:20 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Sounds like it might be running too rich. An adjustment on the fuel/air mixture on the carb may help. Also check your float bowl levels to make sure they are not too high. The only other thing I can think of is that the choke may be sticking. Good luck.
Old Nov 1, 2006 | 08:52 PM
greyghost79's Avatar
greyghost79
sounds like it's running rich.
Old Nov 1, 2006 | 09:05 PM
jerrylee's Avatar
jerrylee
Can I adjust the carb by changing the idle mixture screws in the front of the carb...........Jerrylee///
Old Nov 1, 2006 | 09:19 PM
greyghost79
yes, and "IF" that's the problem that may fix it. but there could be other issues. float level, etc. is the choke ALL THE WAY OPEN when the engine is warmed up? a stuck choke could cause it to run rich too.
Old Nov 1, 2006 | 10:22 PM
694speed350's Avatar
694speed350
when warmed up be sure the choke is completely off.
To Idle...
