Some Intake Manifold Specs
The challenge is to find a manifold that:
Is an aluminum dual plane
Will fit under the stock 72 hood
Has larger ports than stock
Will fit aftermarket heads with 1.19 X 1.99 ports
Will support a 383 build up
And accomodate a Q-Jet or a square bore base carb
Results
Performer - ports 1.14" X 1.88" Height OK
Weiand - ports 1.12" X 1.84" Height OK
Proffessional products Cylone - ports 1.19 X 1.90 Height OK
So the Professional products appears to be the best match. A little port matching and should work out great and meet the challenge.
The fun part is these are really cheap compared to the other brands. I have seen cast/satin finish under $100, polished @ $125 and chrome $160
As we alll know hood clearance is the issue. More room would make more choices available for sure: Performer RPM, Air Gaps, Weiand Action Plus, PP Cyclone Plus, Crosswinds etc....
Mark
BTW plenty of boneyard alum intakes on late 70's and early 80's Camaros, Firebirds, and other GM models with the 350" corporate motor and the Qjet spreadbore. I even found an old Holley made Duntov "Z" single plan at a swapmeet and bought it for only pocket change - kinda want to clean it up and run just for the bragg'n rights.
Found matching corvette number alum intakes to cheap to pass up at the swapmeets.
Hard to choose 1 until u can try it - heck try a few.
Good luck
Need a dual plane for sure, building a low spinning torquer type engine, 308 rear with a TH400 and being a 72. Hood clearance is an issue so my choices are limited....Mark
Mark
81 has more clearance than your 72.
Get the previous 2101 which has the Edelbrock logo directly behind the thermostat housing on the valley cover, rather than on the passenger side runner as on the current design.
I bought a polished Pro Products Crosswind. It's an RPM Airgap clone. The ports were the biggest I found in a dual plane, and matched my AFR 210's near perfectly. The Edelbrock didn't come close, and would have needed porting. I'm impressed with the casting, polishing, machine work, (threads) fit and quality for the price. ($169.) Graham Hansen, author of "Building Big Inch Small Blocks" tested numerous manifolds on a dyno, and had very good things to say about Pro Products. In fact, it beat the RPM Airgap by a few HP. The Crosswind however is too tall for your application. Go with the Cyclone...
Here's mine during a mock up...
www.imagesup.com/usr/79/100_0082.jpg
Eddie
Mark
I wouldn't say I'm finished with bikes but it'll definitely be awhile before I get another one.
I'm gonna probably either get a new Pontiac, new Saturn, or used Caddy for a daily driver after everything is said and done.
Are the runners or openings bigger? What's up with this intake?
thanks
Mark
So when the Performer 2101 & Action+ came out, in general we ignored them as they were to improve on low rise intakes which we didn't run. Comments on the 2101 on the forum sounded like different manifolds were being discussed- i.e. more than 1 2101.
I commented on this privately to another knowledgeable hotrodder forum member a long time ago.
Early or 1st 2101 & Action+ & later stock intakes are similar in appearance regarding runner shape. The Action+ was a little better than the 1st 2101.
A significant improvement was made on the 2nd 2101 Performer & Chevy's bow tie intake which Chevy said was as good as the high rise.
This shows the 2nd 2101 Performer (Chevy's bow tie intake is similar w/ Chevy logo in same place as Edelbrock logo) compared to the Victor Jr.
http://ganeys.home.sprynet.com/VicJrPerf.JPG
Notice the change in runner shape compared to stock type.
The 2101 was changed again to the current or 3rd 2101.
There are racing classes that allow only the current 2101- previous 2101 is illegal.
Confirmation from Edelbrock Tech on 2101 "There were three official versions, ... The early versions weren't necessarily 'better,' but they were tuned for better top end performance while our current generation produces more street friendly low end torque."
Note: Some may be able to add to this as I have no real interest in the low rise intakes except to help those w/ very low hoods.
