Headlights
Old Nov 2, 2006 | 10:41 PM
Dave Witman's Avatar
Dave Witman
Default Headlights
OK I have a 78 vette that I installed Halogen low and high beams. Lows beams work fine but when I turn on the high beams they all start to flash and flicker.I read the search on headlights and from what I read the wiring should be able to handle the halogens without the relay mod. So my question is my headlight switch on the fritz or something else. Dave
Old Nov 2, 2006 | 11:29 PM
PhotoVette1's Avatar
PhotoVette1
The circuit breaker for the headlights is weak or over loading. Try replacing it.
Old Nov 2, 2006 | 11:35 PM
SIXFOOTER's Avatar
SIXFOOTER
yea, that sounds right, the circuit breaker is a self reseting type, thats why they flash.
If you want nice bright headlights your going to have to install relays. Here is a couple pics to get you started. You also should read the article on MADElectrical site.
Here is a good schematic to use.
And here is a pretty good pic of what the arangement can look like, its from BeeJay, forum member
If you want/Need more info, pm me
Old Nov 3, 2006 | 01:13 AM
Bangkok Dean's Avatar
Bangkok Dean
I had a similar problem and found that the ground connection was not good.
Old Nov 3, 2006 | 09:28 AM
Duke94's Avatar
Duke94
I have Halogens on my 78' and they work fine. Check ground wire first.
Old Nov 3, 2006 | 04:12 PM
Dave Witman
OK thanks guys I will have to find the headlight circuit breaker. The grounds should be good its only been 6 mounths since completion of body off. Dave
Old Nov 4, 2006 | 08:56 AM
7T3C3TTZ07's Avatar
7T3C3TTZ07
I had the same problem. The headlight circuit breaker is in the dashboard headlight switch and will open if higher amperage bulbs are used. The standard scenario is when you need more light, you hit the "brights" and 10 seconds later everything goes dark. I went the relay route and everything works fine. With this mod the dashboard circuit breaker only sees the current necessary to operate the relay. I installed three relays: Low beams, High beams and fog lights (to be installed). I used fuses for the lines that connect the battery lead to the lights. All this fits into a 4" x 4" panel near the alternator. You can and probably should clean the ground connection. For my C3 the headlight ground was located on the front side (driver side) of the radiator support. Rather that try to clean all the terminals, I made a new wiring harnes for the the headlights.
Old Nov 12, 2006 | 04:02 PM
Dave Witman
OK I checked the ground and you guys were right to much paint under head of bolt. Thanks Dave
Old Nov 13, 2006 | 12:59 AM
Solid LT1's Avatar
Solid LT1
I will never forget the night I went out to try my H-4 Machal 55-100W bulbs in my 69 Z/28 and found out in a sharp corner doing 70+MPH what the headlight circuit breaker does when it is not happy! I have fried my HL switch by the time I returned to home but, luckily, the low beams still worked. Relay circuit is the best way to go with a high power set-up.
To Headlights
